Steering coupler clamp #2607878
01/17/19 01:35 AM
01/17/19 01:35 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
So I’ve started to put this together and haven’t yet tried to put this dang clamp on.
It seems pretty tough at first, is there any special tricks?
Re: Steering coupler clamp [Re: wkroncke17] #2607888
01/17/19 01:55 AM
01/17/19 01:55 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I installed mine after the column coupler was installed in the car. shruggy
You still need to put the roll pin in the coupler and you cannot do that until the coupler is on the steering box. up
Re: Steering coupler clamp [Re: moparpollack] #2607906
01/17/19 02:27 AM
01/17/19 02:27 AM
Wisconsin
Wisconsin
So does it split apart and the two ends fit in the hole that the roll pin is in?
Any pics of it installed?
