Re: Lokar cable ???
[Re: 70rrclone]
#885055
12/21/10 03:07 PM
12/21/10 03:07 PM
Posts: 5,920 Athens, Greece
Pyper70
Athens, Greece
is anyone using the lokar throttle and or kickdown cables. are they worth it? any idea what lenght is needed for a 70 B body w/440?
thanks Shane
I had bought the Lokar kickdown for my Slant 6 / 904...The parts they give you are rinky dink in my opinion. I had to make my own brackets so they wouldn't go anywhere. Install was easy but I figured for the money I spent it could have been designed better
on my 69 Charger, 440/727...I have the Bouchillon Kit...I love, it was a cinch to install, just study the diagram, cut where it says and load it up. Gives you a multitude of setups. I was sketchy on it because it said that it was for 2bbl/4bbl applications. Holley, Carter, Edelbrock, Demon etc....But I had to figure out where it was going and what pressure since I have Dual Quads. It looks great in the engine bay, looks like a stock piece.
More will chime in with Bouchillon's kit...give it a few
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Lokar cable ???
[Re: Pyper70]
#885056
12/21/10 04:12 PM
12/21/10 04:12 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
thanks Shane
I haven't used either but more people ask questions about the lokar , which is basically a GENERIC kit for everything , the Bouchillon kit is a MOPAR specific kit .
Re: Lokar cable ???
[Re: 70rrclone]
#885057
12/21/10 05:11 PM
12/21/10 05:11 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
Using the Lokar bracket, throttle and kickdown. Easy to install and adjust. Set it up once and never had a problem.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
Re: Lokar cable ???
[Re: 36PLYM]
#885059
12/21/10 08:23 PM
12/21/10 08:23 PM
Posts: 26,470 Rio Linda, CA
John_Kunkel
Rio Linda, CA
People who use the Lokar and claim to have no problems are either lucky or they have a problem and don't know it.
Re: Lokar cable ???
[Re: John_Kunkel]
#885063
12/22/10 12:00 AM
12/22/10 12:00 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
I would not hesitate to install a Lokar throttle cable and/or kick-down cable. Quote:
I must be one of the lucky ones. I have used Lokar cables on my last 5 builds as well as on several friends cars, and now keep a spare one in my tool box to help out others at the track that are having problems.
When Eric Paul's brother was having cable issues at a race in Indy, I installed a Lokar cable on it on the spot in less than 15 minutes to get him up and running again.
The Lokar trans kick down is so smooth I had a guy ask if I disconnected the back two barrels on his carb, because he could no longer feel the pedal get stiff for the secondaries (when actually he had been feeling a bind in the stock kick-down all along, not the carb).
Yes, they are fairly generic, but I work on race cars not show cars, and am used to a little fabrication.
Scott
Re: Lokar cable ???
[Re: 383man]
#885067
12/22/10 08:01 PM
12/22/10 08:01 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
I used both the throttle cable and trans cable on my 69 coronet and they worked great,the gas pedal needed alittle fab work to attach the cable to it but it wasnt hard to do.
Re: Lokar cable ???
[Re: 383man]
#885068
12/22/10 08:13 PM
12/22/10 08:13 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
I had this Lokar cable on my 63 since I put it on the road in 2006 with zero trouble. Works great for me. Ron
Same for me. It bolted right up to my eddy carb
Re: Lokar cable ???
[Re: Triggerfish]
#2607304
01/16/19 01:26 AM
01/16/19 01:26 AM
Posts: 601 Wausau Wi
Convertcuda
Wausau Wi
Anyone got a pic of how they attached cable to gas pedal?
Thanks Ken
Re: Lokar cable ???
[Re: Convertcuda]
#2607589
01/16/19 04:26 PM
01/16/19 04:26 PM
Posts: 20,235 north of coder
moparx
ken, i'm not a fan of the lokar setup for many reasons. with that said, i don't have a 727 kit here, but i have a pic of a 904 kit. it was used for a mockup, then removed. maybe you can see from the pics ? the bracket bolts to the rear carb bolt, then the attaching stud bolts to the carb bracket. if the carb doesn't have the correct bracket, it is a MUST you obtain one. hope this helps.
Re: Lokar cable ???
[Re: 70rrclone]
#2607713
01/16/19 08:45 PM
01/16/19 08:45 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
thanks Shane
they suck,,, factory unit even if you have to modify it is much better.
