Radiator cooling fins break down into 'dust'... #2606547
01/14/19 06:16 PM
01/14/19 06:16 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
This is the second radiator in a number of years that seems to be disintegrating from the outside.
The thin cooling fins between the actual ribs are disintegrating, and turning into a copper-dust/powder.
Car is a daily driven 1973 Dodge Dart.
It's clear some kind of galvanic corrosion is happening here but I'm wondering why because it can't be an 'isolated issue'?
I try to save the radiator and apply a coat of satin black paint on it occassionally, but ofcourse this might slow it down but doesn't seem to stop it.
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606553
01/14/19 06:28 PM
01/14/19 06:28 PM
Out on a limb here but could it be electroyalisis (sp)? Someone said once about with your meter on low volt scale, one probe in the coolant & the other touching the radiator metal & over a certain # of tenths of a volt being generated that there is some galvanic action takeing place (like a battery that is causing corrosion/rusting).
Re: Radiator cooling fins break down into 'dust'... [Re: RapidRobert] #2606557
01/14/19 06:39 PM
01/14/19 06:39 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
That'd be my first guess also. Read this: https://www.hotrod.com/articles/keep-your-cool-preventing-radiator-eating-electrolysis/
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606563
01/14/19 06:52 PM
01/14/19 06:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Do you live by a nuke plant or a military shoot to kill trespass base? eek
Does your pee glow?
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606568
01/14/19 06:59 PM
01/14/19 06:59 PM
The Netherlands
The Netherlands
Not more than usual... smile
I do wonder if the occassional road salt will speed-up the process at hand here.
We've had a very mild winter here uptill now with only one-or-two road salt applications.
As for the electrolysis, I understand, but wouldn't that be happening on the inside of the cooling system where the coolant actually touches the copper (and iron and aluminium).
I could try and stick a voltgauge on various places in/on the cooling system to find voltage-differences.
I've also been thinking of insulating the radiator from the frame it's mounted to. But then again, millions of cars have been made this way. If there was a problem it would have become apparent very quickly I think.
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606570
01/14/19 07:01 PM
01/14/19 07:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Maybe think about a sacrificial anode (zinc?) solution?
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606575
01/14/19 07:12 PM
01/14/19 07:12 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
How old is it? I've seen lots of them do it after they get some age on them. A touch of salt and water, and copper that thin will eventually go poof and disappear.
Kevin
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606576
01/14/19 07:12 PM
01/14/19 07:12 PM
The Netherlands
The Netherlands
Well, I had the idea of coating the radiator with a zinc-primer.
I wonder how an anode will help when it's mounted on the inside of the radiator while the outside is deteriorating.
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606588
01/14/19 07:43 PM
01/14/19 07:43 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My thinking is the current is now flowing to an unknown cathode agent outside the rad, thru the uncoated inner metal, an interior immersed anode would reverse that current flow direction, or at least reduce it.
Re: Radiator cooling fins break down into 'dust'... [Re: jcc] #2606773
01/15/19 02:42 AM
01/15/19 02:42 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
my opinion after 37 years of radiator repair,its salt!!,do you live near the ocean by chance??
my ladder of success is missing some rungs
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2606782
01/15/19 03:47 AM
01/15/19 03:47 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
He lives in the Netherlands, you know where the little Dutch boy put his finger in the dyke to keep the ocean from flooding the countryside. Yeah, he lives by the ocean.
Don't be the exception.
Re: Radiator cooling fins break down into 'dust'... [Re: rhad] #2607016
01/15/19 05:00 PM
01/15/19 05:00 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I too thought of salt or other road de-icing materials. But I assume the problem would be widespread in the OP's region, and therefore he would know the cause. I could be wrong...
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2607079
01/15/19 06:56 PM
01/15/19 06:56 PM
The Netherlands
The Netherlands
Yes I live near the westcoast of the Netherlands. Some 10 miles from the coast.
Road salt is also used vigorously here whenever freezing night time temps are expected.
I think we've had a just very little frost till now but I know the roads have been 'serviced with salt' a few times already.
I tend to believe the road-salt could be a major cause of this issue, even though I don't recall other cars having these issues.
Maybe when the original black paint on the radiator gets to wear 'thin' enough, the salty moisture kicked up by cars driving in front, can do it's thing on the copper better and dissolve it.
I can even see a copper build-up on the dirt on the engine.
Since this is a fresh engine install (few months ago) and I only noticed the copper 'dusting' on the block fairly recently, I also tend to believe the issue mainly happens during the colder months.
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2607180
01/15/19 09:31 PM
01/15/19 09:31 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would say its salt...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2607260
01/15/19 11:50 PM
01/15/19 11:50 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I've got a couple radiators here that have that same problem. Most of these radiators are from the 80s, either replacements of from cars that have seen several winters in this area. Seems the newer replacement radiators have this problem show up a lot quicker then it did with the old original radiators. Gene
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2607516
01/16/19 03:07 PM
01/16/19 03:07 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
I have a radiator doing that in a car that came from Nevada with absolutely no rust underneath (and I assume no exposure to salt and very little to rain).
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2607518
01/16/19 03:11 PM
01/16/19 03:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
We have seen some trucks that were like that where the rad was like paper. If you touch it you were afraid of popping a tube. Those were almost invariably trucks run in areas with high levels of highway salting or trucks run on the coast.
Re: Radiator cooling fins break down into 'dust'... [Re: Butterscotch71] #2607520
01/16/19 03:13 PM
01/16/19 03:13 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I wonder in your case if it could be a caustic agent (alkali) at work, lime dust, etc
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2608762
01/18/19 09:11 PM
01/18/19 09:11 PM
The Netherlands
The Netherlands
Freezing nighttime temps have arrived here in my country and the roads are already turning white, from the salt!
I took some pre-emptive measurements and sprayed a layer of zinc-primer on the front of the radiator. Hope it stays together this winter...
I sometimes think the roads are slippier because of all the salt they dump on them than from some possible frost that might appear on the surface...
Re: Radiator cooling fins break down into 'dust'... [Re: BigBlockMopar] #2608857
01/19/19 01:41 AM
01/19/19 01:41 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I was a radiator guy too. I would say salt is culprit here...that is not similar to the electrolysis I’ve seen. That (electrolysis) usually shows up as black specks on the tubes themselves.
