Page 1 of 3 1 2 3
Is there a fix for wheel wobble on stock suspension? #2607025
01/15/19 05:05 PM
01/15/19 05:05 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Without converting to aftermarket front end kits is there a way to fix wheel wobble on stock suspension?
Here is a video of my wife’s car with some bolt on parts like tubular upper A-arms, aluminum strut rods, strange brakes and cal-track shocks but still running stock lower control arms and torsion bars.
It might not hurt anything but it looks like it would be hard on suspension parts and could break something eventually...
1968 Barracuda wheel wobble video
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607042
01/15/19 05:43 PM
01/15/19 05:43 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Good double adjustable shocks in the front.
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607049
01/15/19 05:56 PM
01/15/19 05:56 PM
an8sec70cuda Offline
https://www.youtube.com/watch?v=91dmTS-UvDc
Here's a better video of what's happening. This is Tig's car by the way.
I can feel mine doing it when it touches down. I don't think it matters what shock you have on it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607050
01/15/19 05:56 PM
01/15/19 05:56 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Originally Posted By WadeMetzinger
Check the idler arm closely.
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607053
01/15/19 06:12 PM
01/15/19 06:12 PM
AndyF Offline
AndyF  Offline
That is a lot of wobble. I'd beef everything up on the steering linkage side. Heavy duty tie rods, billet adjuster, brace the steering box, etc. The road race guys have been doing this for years so the parts are off the shelf from Hotchkis or other road race vendors.
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607057
01/15/19 06:13 PM
01/15/19 06:13 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have the same issue with my 64 dodge, I do not notice it in the steering wheel but people tell me it wobbles when the wheels touch down just like in your video. My car has everything new in the front end. I went to the heim joint link bar and changed the toe-in settings a couple times and never did correct it.
Re: Is there a fix for wheel wobble on stock suspension? [Re: jwb123] #2607060
01/15/19 06:17 PM
01/15/19 06:17 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Doug (dvw) could probably get you straightened out on this if he see's this post.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607063
01/15/19 06:20 PM
01/15/19 06:20 PM
AndyF Offline
AndyF  Offline
I'd probably start with something like this: https://www.hotchkis.net/product/mopar-a...amp;md=&sm=
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607067
01/15/19 06:27 PM
01/15/19 06:27 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Im glad you brought this up. I was told this last season that I was having the same thing and saw it on a vid. I just looked at an older vid and it was not happening. Will check idler/tie rod ends/ball joints/steering box play closely when I get home
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607069
01/15/19 06:30 PM
01/15/19 06:30 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My stuff doesn't have enough power to get the front tires high enough of the ground to create such issues so I have no experience with this. I for one would think that wobble is not the easiest on parts and could also affect your ET run to run. I'd be trying to fix it that's for sure.
Re: Is there a fix for wheel wobble on stock suspension? [Re: an8sec70cuda] #2607088
01/15/19 07:11 PM
01/15/19 07:11 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
After watching that video, there is something very wrong in your steering components. Looks more like a bad idler arm.
Re: Is there a fix for wheel wobble on stock suspension? [Re: Sammy] #2607096
01/15/19 07:22 PM
01/15/19 07:22 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Mine used to do the same thing,only worse. The idler arm bushing was worn out. Put a new Moog idler arm on. Problem solved.
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607154
01/15/19 08:54 PM
01/15/19 08:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Love my tube K rack steering coil over shocks!!! ....carry on! :j
Re: Is there a fix for wheel wobble on stock suspension? [Re: J_BODY] #2607194
01/15/19 09:46 PM
01/15/19 09:46 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Me too !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607212
01/15/19 10:07 PM
01/15/19 10:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A couple of thoughts. First this can only occur if there is movement or flex. If the control arm bushings, idler arm pivot, or strut rod bushings compress and release you will see positive/negative toe change. Additionally there could be hard part flexing. Control arms, tie rod sleeves, ball joints, and even uni-body. So what gets all this started? My feeling is as the A-arms pivot downward and the front of the car raises, the track becomes narrower. When the tires return to the track surface they are being forced outward trying to return to the static track width. This part of the geometry we can not change. Good condition parts, poly bushings are the first step. My bet as stated earlier is the idler arm pivot bushing is a big factor. Tightening the compression on the front shocks helps by slowing the return to earth. I know mine has done it it on occasion when the shock settings are to loose. Look at Tigs car in the video. The RF is wobbling on the way up.
Doug
Re: Is there a fix for wheel wobble on stock suspension? [Re: dvw] #2607309
01/16/19 01:41 AM
01/16/19 01:41 AM
fresno ca
mikeysmopars Offline
fresno ca
My Dart did that same typical Mopar death wabble even with all new bushings, aftermarket uppers and new steering box. A big part of whats going on is we do the alignment specific for drag racing it loses the bump steer and geometry and gain a bunch of caster which works for going straight just not up n down. I went to a Bob's Pro Fab unit with double adjustable shocks and and cured that issue. Much more stable on the top end also. twocents
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607322
01/16/19 02:26 AM
01/16/19 02:26 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
How much caster are you running? That reminds me of a Sprint Car; it's common to see on them, but it's a transient thing, just at one speed. They run a lot of caster.
Re: Is there a fix for wheel wobble on stock suspension? [Re: dvw] #2607373
01/16/19 10:01 AM
01/16/19 10:01 AM
PA
Harry's Taxi 2 Offline
PA
Doug
DVW, do you know about how much toe-in/out change you have throughout your suspension travel range?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Is there a fix for wheel wobble on stock suspension? [Re: J_BODY] #2607393
01/16/19 11:10 AM
01/16/19 11:10 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
me three
Re: Is there a fix for wheel wobble on stock suspension? [Re: WadeMetzinger] #2607426
01/16/19 12:52 PM
01/16/19 12:52 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Wade my car does it just a fraction of that. Mine has RMS tube uppers, RMS Tube Strut rods, and stock lowers with a poly bushing. 5* of positive caster and it drives like a dream on the track and street.
I agree on checking the idler arm but you might also want to take it over to Jim Sams and let him see it.
68 Barracuda Formula S 340
Page 1 of 3 1 2 3
