Re: Stock converter 1967 426 hemi. Find it Where?
[Re: NANKET]
#2606976
01/15/19 03:43 PM
01/15/19 03:43 PM
Posts: 267 New Jersey
69Chrgr
New Jersey
Call Frank Lupo @ Dynamic Converters in Newark Delaware, he may have an original core or point you in the right direction.
[Re: NANKET]
#2607059
01/15/19 06:14 PM
01/15/19 06:14 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The Hemi converter is just a 764 with larger threads in the drive lugs. Some claim to have tapped the lugs oversize in situ.
[Re: NANKET]
#2607120
01/15/19 07:50 PM
01/15/19 07:50 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
The hemi converter has a bump in the case just outside of the snout, the front pump needs to be clearanced so the converter doesn't rub the pump body.
[Re: NANKET]
#2607148
01/15/19 08:46 PM
01/15/19 08:46 PM
John_Kunkel
Rio Linda, CA
The machining you show isn't for a factory Hemi converter which has the same bowl as any other 10 3/4" converter. Only for the 10" and smaller require pump cover machining.
[Re: lewtot184]
#2607151
01/15/19 08:50 PM
01/15/19 08:50 PM
John_Kunkel
Rio Linda, CA
pretty sure a 383 4bbl converter, other than lugs, is the same as a street hemi. Yeah, that's the 764 I mentioned....also used on the /6, 318 and 340.
[Re: NANKET]
#2607248
01/15/19 11:33 PM
01/15/19 11:33 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
I had one in my 68 rr, 383, no modifications to run it.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#2607266
01/15/19 11:57 PM
01/15/19 11:57 PM
Posts: 318 Iowa
ratroaster
Iowa
I had one in my 68 rr, 383, no modifications to run it. Not what I'm saying. You could run a hemi converter on a 383 crank but not vise-versa without the thin bolt heads......
