ALCOHOL CARB #2606744
01/15/19 01:20 AM
01/15/19 01:20 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Is there a difference in setting up a carb for e85. A buddy has a new carb that was just done for methanol. He's moving to efi. I figure by the 15% gas, it may not need to be so rich. 10:1 not enough compression to keep the alcohol in vapor form and combust efficiently? Iron head vs aluminum?
Re: ALCOHOL CARB [Re: A/MP] #2606806
01/15/19 09:57 AM
01/15/19 09:57 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Everything in an alky carb is machined for more fuel flow. You can probably get it pretty close, but might still be a little rich under certain conditions. 10:1 compression should be fine for E85 on street. That's all production cars are, if not less.
Re: ALCOHOL CARB [Re: A/MP] #2606836
01/15/19 11:29 AM
01/15/19 11:29 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
A good alky carb will be way too rich on e85 without real work, and possibly changing boosters.
Re: ALCOHOL CARB [Re: dthemi] #2606862
01/15/19 12:36 PM
01/15/19 12:36 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just for a reference I run 150’s-152’s in my 850 on my small block
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ALCOHOL CARB [Re: A/MP] #2608078
01/17/19 02:42 PM
01/17/19 02:42 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Some comparative numbers as well. Blown 572 E85 2X4 1250's 180's all 8, gasoline boosters
Nitrous 596 2x4 1250's E85 168's all 8, gasoline boosters
Blown 572 with 2x4 1050's with alky type boosters. ALKY 210's all 8
I tried once to jet down a pair of alky dominators to E85. Just way too much signal to ever get right. By the time I had them close I'd changed almost every aspect of the carb, including boosters, jets, emulsion jets, air bleed, squirts+cams, transfer slot, needles and seats, floats. Never again.
Re: ALCOHOL CARB [Re: A/MP] #2608139
01/17/19 04:27 PM
01/17/19 04:27 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Way too rich
Boffin Emeritus
Re: ALCOHOL CARB [Re: polyspheric] #2608522
01/18/19 12:15 PM
01/18/19 12:15 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Originally Posted By polyspheric
Way too rich
HP, and A/F,says on the money lol.
Re: ALCOHOL CARB [Re: A/MP] #2608571
01/18/19 02:04 PM
01/18/19 02:04 PM
Nevada
merpar Offline
merpar  Offline
Nevada
The best answer is fuel injection. EFI or mechanical
