Do You Run A Pinion Snubber or Other Aftermarket Device? #2606375
01/14/19 12:11 PM
01/14/19 12:11 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
With the lower than stock stance on most of our cars, I assume I am not the only one with a snubber that is pretty close to the floor.
I am currently running a stock snubber and do not have any wheel hop issues, but I do feel like it bumps the floor quite a bit going down the road. Doing so within a turn could certainly be problematic.
Do most of you omit it and run something aftermarket for spring wrap? Stock snubber? Nothing?
My rear suspension isn’t ideal at the moment. I have S/S springs in the low position with additional lowering blocks.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2606405
01/14/19 01:02 PM
01/14/19 01:02 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Trim it down to length, and/or increase springrate.
Depending on the amount the car is lowered, you really want a snubber, simply to prevent the driveshaft from digging into the tunnel during heavy acceleration (and maybe some extra load in the back like people.
Ask me how I know smile
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: BigBlockMopar] #2606458
01/14/19 02:39 PM
01/14/19 02:39 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks. First thing I need to do is validate that it is, in fact, touching during normal operation.
2020 RAM 1500
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2606461
01/14/19 02:55 PM
01/14/19 02:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I assume the SS springs have an arch while at rest? If so, I'd concentrate more on replacing/optimizing the leaf spring package and removing/reducing the lower blocks, before spending much time and effort on the snubber solution.
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2606607
01/14/19 08:41 PM
01/14/19 08:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Floor pan will be shiny where it hits, assuming you drive it regular.
Don't be the exception.
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2606696
01/14/19 11:39 PM
01/14/19 11:39 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
There is some obvious contact on the floor surface but it hasn’t worn through the undercoat, the car has 5,000 miles on it.
I measured 0.97” clearance between the top of the snubber and the floor.
2020 RAM 1500
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2606733
01/15/19 01:02 AM
01/15/19 01:02 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, I am used to 100k+ miles so it'll be shiny by then, lol. I don't think I ever actually measured clearances but that sound like what I remember.
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2606887
01/15/19 01:17 PM
01/15/19 01:17 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Another approach could be a half leaf in the forward spring section. Make it a reasonable stout piece, like a cut down main or first leaf. Mount it on top of the main leaf and make sure to add a clamp near the front tip. This provides two benefits, additional wrap resistance under acceleration and reduced tramp under deceleration. The clamped front reduces wrap, the top location reduces tramp. The unaltered rear spring sections allows spring rate to remain intact.
Other methods could be a torque arm arrangement. There are no off the shelf offerings, so this would require some fab work, but could almost be a bolt in depending on design.
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2607017
01/15/19 05:02 PM
01/15/19 05:02 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I run a stock snubber. actually slightly raised up with a few washers and slightly longer bolts... my Challenger is lowered.. snubber does occassionaly hit (chalk marks on top of the rubber) but nothing serious to be concerned about for me.
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2607029
01/15/19 05:07 PM
01/15/19 05:07 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
stock snubber no issues here, I heard guys using chalk or thick grease to see if they are hitting their floor pan
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2607804
01/16/19 11:12 PM
01/16/19 11:12 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm going to pull the snubber off for a little bit and see what happens. I have to break-in a new ring & pinion, so I won't see any wheel hop issues and can evaluate the ride alone.
From there, I'll assess if the S/S springs need some work or help. Thanks all.
2020 RAM 1500
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2621494
02/15/19 12:29 AM
02/15/19 12:29 AM
Hamilton, Ontario Canada
Magnum Online content
Magnum  Online Content
Use the front segment of the leaf springs to control the pinion from rising towards the floor during launch and acceleration. A pinion snubber is a crutch for weak leaf springs.
Trim the rubber so there is no metal to metal contact. This will be a challenge on a lowered car but if it's still hitting you may need stronger springs and or shocks.
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2621757
02/15/19 05:28 PM
02/15/19 05:28 PM
The Netherlands
The Netherlands
So I did some bodywork on the Dart recently and so happened to notice I am 'apparently' not running a snubber...
This weakens my earlier post ofcourse, but in my defence, the experience I have is based on a different car of mine which was lowered more than my Dart.
On the Dart I noticed the narrow 'boss' on the rear-axle snout had made some contact with the body occassionaly but that might very well be from bottoming out once in a while over the idiotic amount of speedbumps we have overhere.
Re: Do You Run A Pinion Snubber or Other Aftermarket Device? [Re: GoodysGotaCuda] #2622537
02/17/19 02:53 PM
02/17/19 02:53 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I take the off and never noticed any difference... the adjustable pinion type snubbers are so tall you can’t even drive the car with them on lowered springs
A new iron curtain drawn across the 49th parallel
