battery box #2605395
01/12/19 02:34 PM
01/12/19 02:34 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I'm going to start working on my car again. I want to get the electrical done. The car has a trunk mounted battery. What battery box will I need to pass tech? Car will not be in the 9's. Can I use a plastic unit or do I need a metal box?
Coming soon!!!!
Re: battery box [Re: Mr.Yuck] #2605444
01/12/19 03:38 PM
01/12/19 03:38 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
If you have a fire wall between the interior and the trunk a battery box is not needed.
"Just a Bracket car dressed up like a streetcar"
Re: battery box [Re: Mr.Yuck] #2605445
01/12/19 03:40 PM
01/12/19 03:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A piece of metal behind the upper seat back is all you need if you don't use a box. It must have an external master shutoff switch in the positive side of the system.
Doug
Re: battery box [Re: Mr.Yuck] #2605477
01/12/19 04:41 PM
01/12/19 04:41 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If there is no sheetmetal rear firewall, a sealed box vented to the outside is needed. The Moroso box works great. Box or not, a rear mounted battery needs to be held down by minimum of 2 3/8" studs or bolts to a framerail or framerail mounted tabs/brackets. The box or battery tray can be attached to the floor however you like. Battery hold downs need to go through to the frame.
Re: battery box [Re: Mr.Yuck] #2605689
01/13/19 12:45 AM
01/13/19 12:45 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I do both anyway, also the speaker holes according to one tech guy.
My plastic marine boxes have passed NHRA tech since 1994; they're mostly interested in 3/8" nuts/bolts & proper hold-down. Mine go through floor with large washers, hasn't been a problem.
Re: battery box [Re: Mr.Yuck] #2605938
01/13/19 04:04 PM
01/13/19 04:04 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks I do have a firewall. The current battery mounts are welded into the rear cage. The car is tubbed so no rear package tray.
Re: battery box [Re: Mr.Yuck] #2605998
01/13/19 05:32 PM
01/13/19 05:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If it has a legit firewall, no box is required. Just proper battery retention.
Re: battery box [Re: Mr.Yuck] #2606065
01/13/19 07:27 PM
01/13/19 07:27 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
This is the trunk....
Re: battery box [Re: Mr.Yuck] #2606562
01/14/19 06:49 PM
01/14/19 06:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the plastic marine style battery box. I also have metal behind my rear seat so I don't have to use a box. But since its a street car and I use the trunk a lot I don't want battery acid getting on any clothes or jackets I put in the trunk. Ron
Re: battery box [Re: Mr.Yuck] #2606566
01/14/19 06:57 PM
01/14/19 06:57 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
why not use a AGM or gel type battery ?
No fluid issues . No need to use a box or vent down here if using this type of battery .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: battery box [Re: tex013] #2607073
01/15/19 06:40 PM
01/15/19 06:40 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Tex
Yes I will most likely be using one of those. I have a Optima from Chumpcar... As far as I know it is still good. If not I'll buy another one.
