Spark plug recommendation #2606409
01/14/19 01:11 PM
01/14/19 01:11 PM
Western New York
sixpackbee Offline OP
Western New York
I need a spark plug number. Autolite or NGK. 572 Hemi. 10.8 compression. Two Quick fuel 950's. Old Weiand TR. Mild mid .600 mech roller. Stage V heads. Mostly street driven. Thanks much.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Spark plug recommendation [Re: sixpackbee] #2606487
01/14/19 04:02 PM
01/14/19 04:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
For regular street plugs autolite 3923 or champion rc9yc are pretty close at 10.75:1 with a wedge/aftermarket head application. The hotter 3924 or rc12yc also works but is a little on the hot side. I've tried to remember ngk numbers and have given up, LOL. Someone else can help with those. I'm going to start out in the same ballpark on my 572 with a little less compression. I would probably start with the colder 3923 on yours and see how you like it. hope this helps.
Re: Spark plug recommendation [Re: ZIPPY] #2606496
01/14/19 04:14 PM
01/14/19 04:14 PM
If you want a non resistor extended gap spark plug try either the Autolite 3910 or 3911 or the equivalent heat range # in NGK, If you want a retracted gap, flush, non resistor plug try Autolite # 3932 or 3933 up
Re: Spark plug recommendation [Re: sixpackbee] #2606508
01/14/19 04:34 PM
01/14/19 04:34 PM
an8sec70cuda Offline
I use NGK 4554 (R5671A-8) in my pump gas 11:1 572" hemi.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spark plug recommendation [Re: sixpackbee] #2606535
01/14/19 05:49 PM
01/14/19 05:49 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Autolite 3910 or 3911 like Cab said - I run the 3911
Re: Spark plug recommendation [Re: DoubleD] #2606833
01/15/19 11:21 AM
01/15/19 11:21 AM
Western New York
Western New York
Thanks guys. Appreciate it!
1959 Bugeye Sprite
1971 MG Midget
Re: Spark plug recommendation [Re: sixpackbee] #2606839
01/15/19 11:42 AM
01/15/19 11:42 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The AR3911 is projected tip, and I may be wrong, but I think is about the same heat range as a 3932 which is a retracted tip, and a pretty cold plug. Great for the track, but I wonder how long it would go really driving a bunch.
Re: Spark plug recommendation [Re: dthemi] #2606940
01/15/19 02:33 PM
01/15/19 02:33 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
iagree he said street driving....so, I recommended street plugs.
Guess that takes the fun out of it
Re: Spark plug recommendation [Re: sixpackbee] #2606977
01/15/19 03:45 PM
01/15/19 03:45 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
NGK BCP7ES
