Re: what is the best book to buy re 413, 426, 440 wedge engines
[Re: 61-63]
#2606456
01/14/19 02:27 PM
01/14/19 02:27 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Don't work on a Mopar without the appropriate engine book. This will be the starting point for your reference. In this case you want the "Big Block Mopar B-RB Engine Book".
2011 Drag Pak Challenger
[Re: 61-63]
#2606612
01/14/19 08:48 PM
01/14/19 08:48 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
The 1962 and 1963 OEM Max Wedge, AKA Super Stock under Plymouth adds, cross ram intakes are the same manifold with the casting number, they both used the same Carter cross ram carbs with the smaller primary throttle blades and that stupid big air screw to set the idle sped and mixtures Mopar change the camshafts, carb size, intake manifold and cylinder heads in 1964, those heads, intake and carbs are way better for making HP and torque than the smaller, earlier OEM ones Good luck are your deal
[Re: 61-63]
#2606677
01/14/19 11:23 PM
01/14/19 11:23 PM
Cab_Burge
That is about the fifth M.W. intake I've seen that mod done to, removed the center divider I've had several opportunities to buy ones like that, I passed on both On your deal with both size carbs I would run the bigger 3705 1964 carbs. I have several 4 hole carb. inserts that will fit into a manifold like that, I've wanted to do some back to back testing on them but no luck yet I did a motor for a local guy who has a manifold like that, it doesn't run as good as he wants it to (do they ever ) but he started off with the wrong carbs, camshaft and exhaust size so there is a lot of changes needed to make that rascal haul tail like it should Have you looked at the new Trick flow # 270 M.W. size heads yet? If not take a look at them I've owned and race several 1963 plymouth M.W. cars in NHRA stock as well as bracket racing
[Re: 61-63]
#2606758
01/15/19 01:59 AM
01/15/19 01:59 AM
Cab_Burge
The intakes are separated side to side but there is a small window to offer a passage between the two sides of the intake, under the throttle linkage boss I think Years ago Diamond Elkins would cut the tops off the cross ram intakes, both Hemi and wedge manifolds, and open up that passage and maybe enlarge the intake port openings a little bit and weld them back together, that was said to be at one of the old Mopar drag race seminars back before 1980 I may convince my customer with his cut up manifold to try the four hole inserts maybe not
[Re: 61-63]
#2607324
01/16/19 02:35 AM
01/16/19 02:35 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The max performance book is good for race builds, but it lacks a lot of the basics about stock or near stock maintenance. For a good outline on rebuilding, I like Don Taylor’s “How to rebuild big block Mopar engines”. It’s from HP books. Lots of the basic rebuild and maintenance is in there. Both of these and a few others are in my library, and I reference Taylor’s book more than any other. The two of those books together will answer just about everything you could ask.
[Re: 61-63]
#3089268
10/26/22 06:36 AM
10/26/22 06:36 AM
Sharley Ganery
Sharley Ganery
Would "How to Build Max-Performance Mopar Big Block Engines" by Car Tech be a good choice? I am interested in parts interchange, the best heads to get, what fits what, etc. I've built engines so have some experience there but know nothing about Mopar engines. I think re 426 would be the best option. It's great that you had such experience in engines. My father has been working at the service station all his life and he wanted me to continue it. But I chose the university and now I write about police brutality, using helpful hints for this. Previously, I did not regret that I chose this path, but now I have doubts. I really like to dig into cars and take everything apart for details. 100% yes, you can't even doubt.
[Re: Cab_Burge]
#3092602
11/08/22 03:58 PM
11/08/22 03:58 PM
Posts: 40 Sour Lake, Texas
61-63
Sour Lake, Texas
That is about the fifth M.W. intake I've seen that mod done to, removed the center divider I've had several opportunities to buy ones like that, I passed on both On your deal with both size carbs I would run the bigger 3705 1964 carbs. I have several 4 hole carb. inserts that will fit into a manifold like that, I've wanted to do some back to back testing on them but no luck yet I did a motor for a local guy who has a manifold like that, it doesn't run as good as he wants it to (do they ever ) but he started off with the wrong carbs, camshaft and exhaust size so there is a lot of changes needed to make that rascal haul tail like it should Have you looked at the new Trick flow # 270 M.W. size heads yet? If not take a look at them I've owned and race several 1963 plymouth M.W. cars in NHRA stock as well as bracket racing A long time between posts here.I think I've run across the answer as to why that center area needs to be in those intakes but have no idea why this is. I'm mainly a Pontiac guy and have restored a number of the early 60s Pontiac dual quad setups for people over the years and recently repopped the linkage for the bathtub intake they made slightly over 40 of in '63. A friend, Mike Garblik, recently built a 46? Pontiac engine to install in a '62 Catalina and dynoed the engine while fine tuning a pair of 750 cfm AFBs installed on a repop of the old bathtub intake. The holes for the carbs on those bathtubs are open, like the ones on my cross ram. During the process of tuning the carbs Mike ran them on the open holes and with what the Pontiac crowd calls a "sheer plate", which is basically a spacer under the carbs that matches the bottom of the carb and extends the throttle bores a half inch or so. The engine performed better with the sheer plate than it with the carbs sitting on the open holes. Logically to me it makes no sense that it does but it does. The bathtub if for sure a single plane deal since it is a big rectangular opening that the runners branch off of. Any way this is my take on why cutting the centers out of a cross ram is not a good idea if one is seeking max performance. I just want a street/cruise in car so the intake will work fine as is for my use.
