Reverse lights #2606157
01/13/19 10:02 PM
01/13/19 10:02 PM
Garry Owen Offline OP
So I picked up a car not long ago and it has some small things to iron out. One is the reverse lights or lack of. It’s a console automatic 68 roadrunner. I’ve seen pictures of a reverse switch mounted to the shifter or a nss, not sure. Anyhow I’m looking to hook up a switch to a key on power supply with either the switch mentioned or maybe fabricate a mount and use a switch like a 4 speed would have.
Any opinions or am I out in left field?
Re: Reverse lights [Re: Garry Owen] #2606182
01/13/19 10:53 PM
01/13/19 10:53 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
68 roadrunner was never available with a console from the factory. So you may be missing all the wiring for the switch. Check it out completely.
Re: Reverse lights [Re: Garry Owen] #2606186
01/13/19 10:55 PM
01/13/19 10:55 PM
Have a part number for the switch? I’ve been googling it but have found it
May have found it. 150 bucks...yikes
Re: Reverse lights [Re: Garry Owen] #2606213
01/13/19 11:49 PM
01/13/19 11:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You could always convert it to 69 and later nuet switch, all in one 3 prong trans switch. Did that on a 68 coronet and with service manual help, it was a very clean swap.
Re: Reverse lights [Re: Garry Owen] #2606226
01/14/19 12:26 AM
01/14/19 12:26 AM
True. I’m going to look at a wiring diagram and see if I can decode.
Re: Reverse lights [Re: buildanother] #2606233
01/14/19 12:35 AM
01/14/19 12:35 AM
that's what I would do (& thru a fuse for protection)
Re: Reverse lights [Re: Garry Owen] #2606247
01/14/19 12:49 AM
01/14/19 12:49 AM
How do you wire the 3 prong switch back into a 68 harness?
Re: Reverse lights [Re: Garry Owen] #2606259
01/14/19 01:18 AM
01/14/19 01:18 AM
Kind of generic but I would run fused 12V down to one of the "outer" pins on the trans "3 pin terminal" connector on the side of the trans & run the other "outer" pin back up front to the reverse light terminal in the bulkhead. OR T into the backup light wire somewhere "convenient" along its front to rear stretch.
Re: Reverse lights [Re: Garry Owen] #2606262
01/14/19 01:24 AM
01/14/19 01:24 AM
The terminal is 2nd down on left looking at the bulkhead from under the hood?
Re: Reverse lights [Re: Garry Owen] #2606265
01/14/19 01:26 AM
01/14/19 01:26 AM
I ain't sure from memory, I would check the diagram at www.mymopar.com
Re: Reverse lights [Re: RapidRobert] #2606322
01/14/19 06:16 AM
01/14/19 06:16 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Put this info on a pic off the net a while back.
Re: Reverse lights [Re: thehemikid] #2606433
01/14/19 01:51 PM
01/14/19 01:51 PM
You made my day until I went out and looked at the inside bulkhead. Nothing corresponds to the other side. That's ok, I'll just have to hunt down the wire from the rear and tap into it.
Re: Reverse lights [Re: Garry Owen] #2606453
01/14/19 02:24 PM
01/14/19 02:24 PM
moparx Online content
moparx  Online Content
i "think" the rooster comb on the valvebody is different for the 66-68, preventing you from using the 69 up NSS.
JK or mr. cope would be able to clear that up for sure.
beer
Re: Reverse lights [Re: Garry Owen] #2606485
01/14/19 03:59 PM
01/14/19 03:59 PM
Just got under the car and there’s a 3 pin plug already there. The motor is a early 70’s cast number so the trans may be also. I chased the wire back behind the kick panel from the rear and the violet wire is still in the block so that’s probably where I’ll tap in and like Robert said to run into a fused 12v.
Re: Reverse lights [Re: Garry Owen] #2606551
01/14/19 06:25 PM
01/14/19 06:25 PM
& confirrm the 2 outer pins have no continuity (to each other nor to ground, the trans case) in all positions other than reverse & that they are connected/have continuity (to each other) in reverse.
