compression question-.030 over 440 #2605937
01/13/19 04:01 PM
01/13/19 04:01 PM
moparx Offline OP
moparx  Offline OP
can an aluminum head [pocket ported eddy performer rpm] with an 11.0:1 CR be ran with 93 pump gas [with adding ?? amount of race gas or additive] in a 4000lb charger, MP590 cam, 3.91gear by backing timing down to around 18[or so] initial, 32-34 total, without detonation ?
i know this is on the ragged edge, but just asking.
how much will this affect performance ?
a head gasket change can [i think] lower the CR to around 10.5:1 or so.
other suggestions ?
TIA up
beer
Re: compression question-.030 over 440 [Re: moparx] #2605993
01/13/19 05:29 PM
01/13/19 05:29 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I'm not sure I understand the question. If you are willing to blend race gas, yes you can run it just fine, and you will not need to reduce your timing.
Re: compression question-.030 over 440 [Re: moparx] #2606000
01/13/19 05:35 PM
01/13/19 05:35 PM
Kirkland, Washington
Pacnorthcuda Offline
You haven't addressed the variables of dynamic compression (determined by intake valve closing event) and quench.
There is no yes or no to your question but rather a maybe.
With quench, with a late intake valve closing, that 'maybe' heads towards a 'probably'.
Re: compression question-.030 over 440 [Re: moparx] #2606059
01/13/19 07:07 PM
01/13/19 07:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd bet that combo would come very close to running on Pump gas. We run 10.5-1 with a Mopar .557 cam, full timing.
Doug
Re: compression question-.030 over 440 [Re: dvw] #2606064
01/13/19 07:25 PM
01/13/19 07:25 PM
moparx Offline OP
moparx  Offline OP
well guys, i screwed up. [well that's not a surprise ! whistling]
it's 11.6. zero deck, flat tops, 79cc heads, .019 head gaskets.
gotta change head gaskets. so guessing .040-.050 thick to lower it to around 10.5 or so ?
next would be, how much torque will be lost ?
sorry for the screwup on my end ! blush
beer
Re: compression question-.030 over 440 [Re: dvw] #2606068
01/13/19 07:31 PM
01/13/19 07:31 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Doug
Yup.
I'm at 10.8 CR, pretty late intake closing, blows about 195 psi, and it works, but on the edge.
Re: compression question-.030 over 440 [Re: BSB67] #2606080
01/13/19 07:57 PM
01/13/19 07:57 PM
If you are up & running (nice weather will be here before you know it) you might just proportion in a bigger % of race gas. On a side note wallace raceing & united machine have very user friendly CR calculators (& other services).
Re: compression question-.030 over 440 [Re: moparx] #2606082
01/13/19 08:01 PM
01/13/19 08:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The combo I spoke of runs a 4.10, old Weiand 2x4, 2 600 Eddy's, untouched Eddy RPM heads, headers, and a decent converter in a 65 Belvedere, 3750lb race weight. Been 11.30's.
Doug
Re: compression question-.030 over 440 [Re: moparx] #2606087
01/13/19 08:10 PM
01/13/19 08:10 PM
AndyF Offline
AndyF  Offline
You're still guessing at the numbers which is a bad sign. The math isn't difficult so you should sit down and figure out what gasket thickness you need to get to 10.5 compression. 0.040 or 0.050 isn't going to take you from 11.60 to 10.50.
You might be able to have Cometic build you a super thick gasket but once you do that you're going to have assembly problems. If you want that engine to run on pump gas you'll need to pull it apart and add a shallow dish to the pistons or open up the heads a bit.
Re: compression question-.030 over 440 [Re: moparx] #2606123
01/13/19 09:15 PM
01/13/19 09:15 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Open or closed chamber head? If they're closed, that .019 gasket is a non starter anyway with zero deck.
I'm not sure how much credence there is to the so called rule of thumb that says aluminum will support a point more compression than iron will before detonation, but if it will and you have closed chamber heads, guessing your gasket bore at 4.4 and 4cc valve reliefs, my calculator comes up with 10.8:1 with a .039 gasket. .039 gives you a safe piston to head and excellent quench distance which is critical to make a pump gas combo work.
With an MP590 it should be good with brand name 93. 100 degrees of overlap should help bleed a bunch of cylinder pressure at low RPM.
I'm not sure if I'm confusing BSB67's build with someone else's but I thought he ran the MP528 which is supposed to have 60 deg of overlap, so if he doesn't rattle at 10.8, you should be golden.
You might have to play with the timing curve a bit depending on what converter and rear gear your are trying to haul 4000 lbs out of the hole with.
Kevin
Re: compression question-.030 over 440 [Re: moparx] #2606130
01/13/19 09:29 PM
01/13/19 09:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
beer
1cc will change static compression about 1/10th of a point, some slight variables. you'll still be 11:1 with gasket change. add in some carbon build-up and your back the 11.5+. that's internet/magazine pump gas doable; but not in the real world.
Re: compression question-.030 over 440 [Re: lewtot184] #2606161
01/13/19 10:08 PM
01/13/19 10:08 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
beer
so if you go to a .060 cometic summit sells. Its around 15cc compared to .019 4.5cc it would put you down 1 point to 10.5
Re: compression question-.030 over 440 [Re: plycuda] #2606391
01/14/19 12:49 PM
01/14/19 12:49 PM
moparx Offline OP
moparx  Offline OP
looks like i'll be taking it apart and do a check and measure, then go from there. thanks all ! will report back at a later date.
beer
Re: compression question-.030 over 440 [Re: moparx] #2606396
01/14/19 12:53 PM
01/14/19 12:53 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Not to mention what a “wonderful” street combo that would make......
10.5cr, 590 cam, 4000lb car.
As far as getting the cr pump gas friendly and still have good quench....... the numbers work out fine for me:
914- swept
10- gasket(.040)
1- area above rings
6- typical valve pockets
79- chamber
1010- total
96- total minus swept
10.52:1- 1010/96
Re: compression question-.030 over 440 [Re: fast68plymouth] #2606417
01/14/19 01:26 PM
01/14/19 01:26 PM
moparx Offline OP
moparx  Offline OP
fast, are you just joshin' me about that being a good street combo, or will it truly be an ok deal ?
beer
Re: compression question-.030 over 440 [Re: moparx] #2606432
01/14/19 01:51 PM
01/14/19 01:51 PM
So. Burlington, Vt.
So. Burlington, Vt.
I thought the “ “ were self explanatory.
It wouldn’t be my idea of a good combo, but I’m sure there are people running similar set ups that they’re happy with.
Re: compression question-.030 over 440 [Re: moparx] #2606460
01/14/19 02:52 PM
01/14/19 02:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
When on the edge, anything to reduce inlet air temp will help.
Re: compression question-.030 over 440 [Re: moparx] #2606468
01/14/19 03:10 PM
01/14/19 03:10 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
as mentioned dynamic compression is what controls what octane fuel you need, much more than static compression. And there are computer engine programs that will calculate dynamic compression, how prone an engine is to spark knock. I use performance trends engine analyzer, it gives me cranking compression, idle vacuum, dynamic compression, and calculates a spark curve for what ever octane fuel you want to use, including alcohol. For the cost of the program, you could not buy a set of pistons. It also has a calculator function for actual static compression using piston height and chamber CC's. When I take the time to measure, seldom doe an engine have as much compression as the paperwork states.
Re: compression question-.030 over 440 [Re: fast68plymouth] #2606899
01/15/19 01:29 PM
01/15/19 01:29 PM
moparx Offline OP
moparx  Offline OP
that was what i thought you were implying. biggrin
beer
Re: compression question-.030 over 440 [Re: moparx] #2607114
01/15/19 07:43 PM
01/15/19 07:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
other suggestions ?
TIA up
beer
I ran an 11.25:1 Stage VI headed (very worked) 440-6 on the street w/ 93 w/o issue. I did have a Meth/H2O injection kit for the track. Much cheaper than mixing gas. I had the timing at 37* all in at 2400. car was a 70 charger 3800+lbs 3800 stall 3.91's went 11.28@121
Coming soon!!!!
