72-93 Transmission line interchange #2606050
01/13/19 06:51 PM
01/13/19 06:51 PM
IA
TLT Offline OP
TLT  Offline OP
IA
Putting my 1985 D-150 regular cab longbox 318/727 back together, I would like to buy a set of pre-bent transmission lines, all I can find is a set for 78-79 D/W 150, as 72-93 trucks are basically the same, would these work? Maybe a few minor tweaks?
Re: 72-93 Transmission line interchange [Re: TLT] #2606192
01/13/19 11:05 PM
01/13/19 11:05 PM
ND
dodgedon Offline
dodgedon  Offline
ND
I bought new lines for my 85 W350 from inline tube. part number DTT 8731
https://board.moparts.org/ubbthreads/ubbt...lines%20002.JPG
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 72-93 Transmission line interchange [Re: TLT] #2606202
01/13/19 11:25 PM
01/13/19 11:25 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
I knew I had seen them somewhere , www.vansauto.com p/n CHZTCL024 Paul
Re: 72-93 Transmission line interchange [Re: TLT] #2606273
01/14/19 02:03 AM
01/14/19 02:03 AM
IA
TLT Offline OP
TLT  Offline OP
IA
Inline Tube doesn't recognize that number, vansauto.com had them listed for 80-89 Dodge trucks, no mention of 2 or 4 wd, on the way way and crossing my fingers! Thanks all for the info!
Re: 72-93 Transmission line interchange [Re: TLT] #2606687
01/14/19 11:33 PM
01/14/19 11:33 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
IIRC...the older trucks use solid lines, and the newer trucks have a flexible section that connects to the radiator.But they should interchange I would think.
1981 Dodge D150 360 auto
