Can Hydraulic Lifters Get Stuck "Pumped Up"?
#2605842
01/13/19 01:18 PM
01/13/19 01:18 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I'm running a XE274 comp cam & lifters (hydraulic) with Isky adjustable rocker arms & ball/cup pushrods. The cam has about 500 miles on it. I'm also running old Direct Connection "green stripe" double valve springs. I just set the valve last 3 days ago using the Direct Connection valve lash adjustment method & turned adjuster screws in 3/4 turn after "zero lash"
I've been trying to determine why I have so much noise under my valve covers. I hear these cams are noisy, but this "seems" like too much noise. It's coming from both valve covers.
I pulled one valve cover & noticed that #8 intake rocker arm is adjusted WAY "taller" than the other rockers (like the pushrod is longer). I pulled two pushrods & verified that the #8 intake pushrod is the same length as the others.
So....Is it possible for a lifter to be broken in the "pumped up" position?
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Can Hydraulic Lifters Get Stuck "Pumped Up"?
[Re: PurpleBeeper]
#2605848
01/13/19 01:23 PM
01/13/19 01:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Think about this, your adjust thread is probably 24tpi, one full turn of preload will be approximately .040", 3/4 of a turn is .030". "Way taller" to me seems considerably more than .030". So even if the lifter maxed out that's all it could raise it.
Slack in the valve train is what usually makes noise.
[Re: Supercuda]
#2605850
01/13/19 01:28 PM
01/13/19 01:28 PM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
You most likely lost the snap ring in the top of the lifter. That will allow the lifter plunger to come up higher in the lifter body causing your problem.
[Re: PurpleBeeper]
#2605859
01/13/19 01:41 PM
01/13/19 01:41 PM
RapidRobert
I pulled one valve cover & noticed that #8 intake rocker arm is adjusted WAY "taller" than the other rockers. This is on base circle? I would readjust em again by getting the dampener on #1 TDC compression & doing both #1 in/ex then a 1/4 turn & doing #8 & so on. You can cut a strip of paper 5.694" (5&11/16) to use as a ruler on your dampener. pull the plugs will make it easier (we don't need more exercise do we!). What Supercuda said, slack is noise.
[Re: PurpleBeeper]
#2605868
01/13/19 01:54 PM
01/13/19 01:54 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Thanks gentlemen, I have not put the #8 intake lobe on the base circle of the cam yet & I definitely need to check it that way. It just looked really odd that ONE adjustment screw was very noticeably "taller" than all the rest of the rocker arms.
IF the snap ring broke on this lifter & that lifter's plunger got stuck up higher than the other lifters (basically making this lifter a taller solid lifter), then it would explain the adjustment difference. My "thought" was that maybe the pushrod on this valve is contacting the base of that rocker arm causing the noise?
It think I may need to get a magnetic tool & slide out that lifter and one more to compare them.
Any more ideas? I will at the very least be re-setting the valve lash on this side of the motor (& likely more)
[Re: PurpleBeeper]
#2605900
01/13/19 03:04 PM
01/13/19 03:04 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Hey Lew, maybe I have the name wrong, but the springs are the very old Direct Connection dual springs that were listed for the smaller solid lifter cams & as "optional" on the old original Direct Connection purple shaft 292/509 hydraulic cam. This motor was built in 1985 & I have since changed the camshaft (fyi).
At one point I did replace two of the Isky ball/cup pushrods, which made me wonder if my replacements were accidentally the solid-lifter version (slightly longer vs. hydraulic pushrods)…..checked that & the pushrod matches the other ones.
It's just that this one adjustment screw is so much different than the others (visually). My only thought are: a. I missed adjusting that rocker b. That valve has a push rod too long (checked that, not it) c. The lifter is stuck in the fully pumped up position d. My rocker shaft is loose, so my valve lash adjustments are WAY off.
This all started tracking down valve gear noise. I double checked my rocker/valve cover clearance...no "witness marks" on valve cover baffles. I don't think I have any bent pushrods, but I will roll them all on a mirror just to be sure.
Any other thoughts?
[Re: PurpleBeeper]
#2605936
01/13/19 04:01 PM
01/13/19 04:01 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2605978
01/13/19 05:06 PM
01/13/19 05:06 PM
Posts: 16,154 Mesa, Arizona
dart4forte
Mesa, Arizona
Seems the last 20 years lifters seem to have gone down in quality. Constantly dealing with the lifters bleeding down after sitting for a few day. I went through several sets of lifters from aftermarket cam vendors with the same problem. Finally found a couple of sets of NOS lifters, problems solved. Nice and quiet.
Abe Lincoln
[Re: bee1971]
#2606013
01/13/19 06:02 PM
01/13/19 06:02 PM
Porter67
Your killin me here, that dont sound like a 318, that sounds like my solid camed stroker. Unless im hearing a lil piston slap, which I doubt. Also you have the thick thick al. valve covers. If you had the steel or the thin squared off china made covers youd be much louder. Sounds good though.
[Re: PurpleBeeper]
#2606014
01/13/19 06:02 PM
01/13/19 06:02 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
It’s a sound that was hard to adjust to (No pun intended) if you have not heard similar fast rate cams
Especially after running a Mopar 284/484 Camshaft and lifters for 25 years in the same block Nice and quiet at idle , right up until I kissed a piston with an intake valve
Hence the rebuild last year
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: PurpleBeeper]
#2606022
01/13/19 06:10 PM
01/13/19 06:10 PM
bee1971
Sobieski Wi
Point I was trying to make is Purplebeeper might not bee hearing anything unusual
Other then the fact of the XE 274 Camshaft and lifters fast rate sewing machine
That’s why I posted that video of the same cam off YouTube in a 440
[Re: PurpleBeeper]
#2606027
01/13/19 06:12 PM
01/13/19 06:12 PM
Supercuda
About to go away
About to go away
up yours
It just looked really odd that ONE adjustment screw was very noticeably "taller" than all the rest of the rocker arms. You did not say screw in your initial description. If that adjusting screw is sticking out farther than the others did you check your lash? Sounds like the screw loosened not the lifter pumped up. how does it lock the adjusters? Since you already pulled the valve train apart just eyeball the lifter and see if the snap ring is there but that doesn't sound like the problem.
[Re: PurpleBeeper]
#2606029
01/13/19 06:14 PM
01/13/19 06:14 PM
bee1971
Sobieski Wi
Purplebeeper can you post a video and sound of your motor at idle once you have it back together ?
[Re: bee1971]
#2606030
01/13/19 06:15 PM
01/13/19 06:15 PM
Porter67
I mis read your first reply, sorry. Point I was trying to make is Purplebeeper might not bee hearing anything unusual
[Re: Porter67]
#2606036
01/13/19 06:17 PM
01/13/19 06:17 PM
bee1971
Sobieski Wi
That’s why I posted that video of the same cam off YouTube in a 440 LOL Roger Me pecking on my IPad and watching football at the same time
