How much can you bore a 360? #260566
03/21/09 10:44 AM
03/21/09 10:44 AM
PA
KGorney Offline OP
KGorney  Offline OP
PA
What's the max overbore for a 360?
I have a block that was already bored .030 over but to use it will require more boring to cleanup.
Is .060 over getting too thin on the cylinder wall?
This is for a 49 Dodge that will be a street car.
Re: How much can you bore a 360? [Re: KGorney] #260567
03/21/09 11:09 AM
03/21/09 11:09 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Have the block checked by the machine shop before being bored. There really is no standard "limit"
Re: How much can you bore a 360? [Re: KGorney] #260568
03/21/09 11:16 AM
03/21/09 11:16 AM
.060" would "probably" be Ok but I'd have it sonic checked. It doesn't cost that much & with the block being the foundation & you wouldn't want to go any further with machining $$$ without knowing that your core is going to be good. I dont assume anything these days. Been bit too many times
Re: How much can you bore a 360? [Re: RapidRobert] #260569
03/21/09 12:16 PM
03/21/09 12:16 PM
PA
KGorney Offline OP
KGorney  Offline OP
PA
Thanks.
I definitely plan to have the block cleaned and checked at a machine shop. The crank and rods as well. I just wondered what the general consensus and experience was boring past .030 before I invest any in the block.
Re: How much can you bore a 360? [Re: KGorney] #260570
03/21/09 02:39 PM
03/21/09 02:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not just go .040 over.Pistons are easy to find and that wouldn't be pushing the thin wall trouble.
Re: How much can you bore a 360? [Re: stumpy] #260571
03/21/09 02:41 PM
03/21/09 02:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
.040 will be no problem.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: How much can you bore a 360? [Re: MoparforLife] #260572
03/21/09 04:43 PM
03/21/09 04:43 PM
PA
KGorney Offline OP
KGorney  Offline OP
PA
I'll go .040 if I can, but I don't know if that will be enough to clean up the cylinder walls.
Re: How much can you bore a 360? [Re: KGorney] #260573
03/21/09 05:07 PM
03/21/09 05:07 PM
Louisville Ky.
P
Pir8Darryl Offline
Pir8Darryl  Offline
P
Louisville Ky.
The 360 is one of the very rare engines that can handle a big overbore with no problems... Provided it's one cast after 1975.
When the 360 was released in 1970, it used it's own unique sand casting molds, but there were problems as the longer stroke would side-load the pistons and casue the block to crack in the main web area.
To remidy the problem, Mopar re-designed the casting by using the 340 internal cylinder molds, and adding additional meat in the main web areas.
Since the later 360 uses the 340 mold cores, if you bore it out to 4.04 [.040 over], it's just a standard 340 bore... But there's lots more meat to exploit if you choose.
Back in the late 70's and early 80's, there were a few guys who bored the 360 block .130 over, and use ford 428 flattop pistons for a 383 small block.
Needless to say, if your gonna hog out the holes like that, it's going to need to be sonic checked to find the center of the casting... But there is enough meat there to do it.
Re: How much can you bore a 360? [Re: Pir8Darryl] #260574
03/22/09 01:53 AM
03/22/09 01:53 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Straight from my Mopar "Engines" book, pg 31:
Re: How much can you bore a 360? [Re: vdriver] #260575
03/22/09 07:43 AM
03/22/09 07:43 AM
Louisville Ky.
P
Pir8Darryl Offline
Pir8Darryl  Offline
P
Louisville Ky.
My most humble appologies, and a sincere thank you for setting my facts straight.
So it was the early 360 blocks that were the "good ones", and not the late blocks. Ok, I'm down with that. I was going off memory of something I saw 30-some years ago... Sux getting older.
Re: How much can you bore a 360? [Re: Pir8Darryl] #260576
03/22/09 08:21 AM
03/22/09 08:21 AM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
Id just have it sonic checked reguardless of the year. Mopars can be so random on some things that I wouldnt take any mopar book as the gospel. I bought a 318 (3.91 bore) that had been bored to 4.07 (.030 over 340). All the numbers on the block said 318 on it and it took a 318 drivers mount. Didnt have an x or anything else stamped on it out of the ordinary. I drove the motor about 2 months without any trouble. Ive been told so many things thhat this engine was but who knows?
Re: How much can you bore a 360? [Re: derekeh] #260577
03/22/09 08:28 AM
03/22/09 08:28 AM
have it sonic checked & read Andys extensive block sonic check procedure that he did with a # of blocks that's probably in the archives
Re: How much can you bore a 360? [Re: RapidRobert] #260578
03/22/09 08:43 AM
03/22/09 08:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That only pertains to BIG BLOCKS .
But yes have it cleaned and sonic checked first .
Re: How much can you bore a 360? [Re: JohnRR] #260579
03/22/09 09:22 AM
03/22/09 09:22 AM
That only pertains to BIG BLOCKS.
The study was done with big blocks but it would stand to reason that the same would apply to SB's also. with MP's tooling/machining procedures I see no reason why it would not apply. If the OP reads the article he will see that it was performed on BB's & he will be able to draw his own conclusions.
Re: How much can you bore a 360? [Re: RapidRobert] #260580
03/22/09 03:35 PM
03/22/09 03:35 PM
dogdays Offline
dogdays  Offline
I'm with RR. Casting irregularities mean more than year of casting except for the first three. With 360 blocks in the $100 range, you could also get a different block. But if you're starting a rebuild a sonic check is good insurance.
R.
Re: How much can you bore a 360? [Re: dogdays] #260581
03/22/09 03:52 PM
03/22/09 03:52 PM
Thanks Dog, backup is always appreciated. When the "thin wall" casting started in I think the '75 model year the first # went from a 3 to a 4 in the block casting # on the side of the block on both sb's and bb's but how/why alot of these "later" ones ended up being thicker I dont have a clue.
Re: How much can you bore a 360? [Re: vdriver] #260582
03/22/09 04:42 PM
03/22/09 04:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Don't put too much stock in something just because it's written in a book. For 30 years the mid-late 70's 440's suffered from the 'thin wall' label too, which turned out to be BS.
