Re: How much can you bore a 360?
[Re: KGorney]
#260568
03/21/09 11:16 AM
03/21/09 11:16 AM
RapidRobert
.060" would "probably" be Ok but I'd have it sonic checked. It doesn't cost that much & with the block being the foundation & you wouldn't want to go any further with machining $$$ without knowing that your core is going to be good. I dont assume anything these days. Been bit too many times
[Re: KGorney]
#260573
03/21/09 05:07 PM
03/21/09 05:07 PM
Posts: 30 Louisville Ky.
Pir8Darryl
Louisville Ky.
The 360 is one of the very rare engines that can handle a big overbore with no problems... Provided it's one cast after 1975.
When the 360 was released in 1970, it used it's own unique sand casting molds, but there were problems as the longer stroke would side-load the pistons and casue the block to crack in the main web area.
To remidy the problem, Mopar re-designed the casting by using the 340 internal cylinder molds, and adding additional meat in the main web areas.
Since the later 360 uses the 340 mold cores, if you bore it out to 4.04 [.040 over], it's just a standard 340 bore... But there's lots more meat to exploit if you choose.
Back in the late 70's and early 80's, there were a few guys who bored the 360 block .130 over, and use ford 428 flattop pistons for a 383 small block.
Needless to say, if your gonna hog out the holes like that, it's going to need to be sonic checked to find the center of the casting... But there is enough meat there to do it.
[Re: Pir8Darryl]
#260574
03/22/09 01:53 AM
03/22/09 01:53 AM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
Straight from my Mopar "Engines" book, pg 31:
[Re: vdriver]
#260575
03/22/09 07:43 AM
03/22/09 07:43 AM
Pir8Darryl
Louisville Ky.
My most humble appologies, and a sincere thank you for setting my facts straight.
So it was the early 360 blocks that were the "good ones", and not the late blocks. Ok, I'm down with that. I was going off memory of something I saw 30-some years ago... Sux getting older.
[Re: derekeh]
#260577
03/22/09 08:28 AM
03/22/09 08:28 AM
RapidRobert
have it sonic checked & read Andys extensive block sonic check procedure that he did with a # of blocks that's probably in the archives
[Re: RapidRobert]
#260578
03/22/09 08:43 AM
03/22/09 08:43 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
That only pertains to BIG BLOCKS .
But yes have it cleaned and sonic checked first .
[Re: dogdays]
#260581
03/22/09 03:52 PM
03/22/09 03:52 PM
RapidRobert
Thanks Dog, backup is always appreciated. When the "thin wall" casting started in I think the '75 model year the first # went from a 3 to a 4 in the block casting # on the side of the block on both sb's and bb's but how/why alot of these "later" ones ended up being thicker I dont have a clue.
[Re: vdriver]
#260582
03/22/09 04:42 PM
03/22/09 04:42 PM
DaytonaTurbo
Manitoba, Canada
Don't put too much stock in something just because it's written in a book. For 30 years the mid-late 70's 440's suffered from the 'thin wall' label too, which turned out to be BS.
