Anyone have a pic of how to install the moog o/s UCA #260551
03/21/09 10:28 AM
03/21/09 10:28 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I know there is a good pic out there on how to install the offset upper control arm bushings, but I have tried google and everything else and I can not find it...
Also, do you need to install all 4 or will 2 give you enough caster?
I know there is a good pick that Rick E-burg has in mopar action but I can not find it...
I am talking about the Moog K7103 bushings that are offset.
THANKS in advance,
6t6
Re: Anyone have a pic of how to install the moog o/s UCA [Re: 6T6Cuda] #260552
03/21/09 10:55 AM
03/21/09 10:55 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I do't have a pic but I would recomend installing the front bushings with the hole off set to the inside/away from the ball joint and the rear bushing with the hole offset to the out side/closet to the ball joint on each arm. This will give you the most possible caster and that is what's lacking from the factory set up's.
Re: Anyone have a pic of how to install the moog o/s UC [Re: 6T6Cuda] #260553
03/21/09 11:02 AM
03/21/09 11:02 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
sorry no pic but you basically want to set the upper ball joint as far back (towards the rear) as possible if you want more caster. so if you lay the control arm flat on a table the front bushing has the hole further away from ball joint and the rear bushing is closer to the ball joint. not sure if you will need all 4 or not. hope this was a little helpful.
i see wild bill beat me to it
Re: Anyone have a pic of how to install the moog o/s UC [Re: dirtybee] #260554
03/21/09 11:15 AM
03/21/09 11:15 AM
abodyman Offline
super street
abodyman  Offline
super street
You do need all 4
and there IS a pic in the tech archives.
Look under suspension.
Re: Anyone have a pic of how to install the moog o/s UC [Re: abodyman] #260555
03/21/09 01:40 PM
03/21/09 01:40 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Also, check all the boxes, there is an instruction sheet describing the correct installation that for some reason does not always make it to the customer in the box.
I may have kept one of the instruction sheets for reference. I'll check and post if I have one.
Re: Anyone have a pic of how to install the moog o/s UC [Re: Lefty] #260556
03/21/09 02:48 PM
03/21/09 02:48 PM
BDW Offline
BDW  Offline
I put this together a while ago, I didn't create this, just modified the original so I could understand why the offset bushings helped.
Re: Anyone have a pic of how to install the moog o/s UC [Re: Lefty] #260557
03/21/09 03:02 PM
03/21/09 03:02 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Also. be aware that even IF you find the instruction sheet, it might NOT show the installation for maximum increase in caster. Instead, it might show how to install to get the most increase in camber. The two methods differ in how the rear bushing is installed. Both methods would have the front bushing installed so that the control arm is shifted OUT.
To increase camber, the rear gets installed the same way (shifting the arm OUT). To increase caster (which is what you want), the rear gets installed shifting the arm IN, as is shown by the diagram in the post previous to mine.
Down to just a blue car now.
Re: Anyone have a pic of how to install the moog o/s UC [Re: 68HemiB] #260558
03/21/09 05:07 PM
03/21/09 05:07 PM
Lefty Offline
Lefty  Offline
Good info! Thanks...
EDIT - My bad...
Re: Anyone have a pic of how to install the moog o/s UC [Re: Lefty] #260559
03/21/09 11:04 PM
03/21/09 11:04 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Thanks to all, I have them on order, but I wanted to make sure I knew how to install them before I got everything together...
Re: Anyone have a pic of how to install the moog o/s UC [Re: 6T6Cuda] #260560
03/22/09 12:40 AM
03/22/09 12:40 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Where are you getting you parts just curious, I'll be doing this real soon as well. Also, can any one explain simply, what a positive caster does for handling?
Thanks.
Re: Anyone have a pic of how to install the moog o/s UC [Re: cudabitten] #260561
03/22/09 12:48 AM
03/22/09 12:48 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I am getting the bushings from Summit; about the same price as anywhere (except the local parts stores); I was combining it with some other things I needed...
Caster is like the wheel a shopping cart, more caster will cause the wheel to track "straight" the advantage is better control at higher speeds at the expense of some additional steering effort.
Our cars where designed for bias plys and they apparently did not need as much caster to track straight, so there was not that much adjustment in the orig setup...
Re: Anyone have a pic of how to install the moog o/s UC [Re: 6T6Cuda] #260562
03/22/09 08:48 AM
03/22/09 08:48 AM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
I got mine from rockauto.com last week.
Re: Anyone have a pic of how to install the moog o/s UC [Re: 500Stroker] #260563
03/22/09 09:35 AM
03/22/09 09:35 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Mine were just ordered from autopartsgiant.com, they beat all of rockauto.com prices and had free shipping.
I only got the offsets for the front and regulars for the rear. I was told the fronts only needed to be done?
Re: Anyone have a pic of how to install the moog o/s UC [Re: cudabitten] #260564
03/22/09 11:59 AM
03/22/09 11:59 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Thanks.
The more positive caster a front end has, the more it "wants" to point straight ahead. What this also means is that it takes more effort to turn it away from straight ahead. When vintage Mopars were originally built, one of the perceived benefits of engineering cars and creating alignment specs with little (or negative) caster was reduced steering effort. Concern with better stability and handling trumps that in today's world.
Another analogy for positive caster stability would be riding a bicycle. Bikes generally have positive caster. If you extend an imaginary line through the steering pivot (the front frame tube holding the fork/handlebars), that line intersects the ground forward of a vertical line through the axle shaft. Because of this, the wheel "wants" to stay straight and track "behind" the imaginary pivot line. This is why, at speed, one can ride a bike without even holding the handlebars.
Re: Anyone have a pic of how to install the moog o/s UC [Re: 68HemiB] #260565
03/26/09 01:58 PM
03/26/09 01:58 PM
Long Island, New York
Tony H Offline
Tony H  Offline
Do you guys recommend buying the OFFSET bushings all the time?
Stock '70 valiant in desperate need of Uppers. Just trying to get a handle on it. NAPA sells 'Stock' and Additional Caster Adjustment ones... The car is stock, If I go with additional caster bushings, will it be a problem? How tough are these pressed in? Can I get them in with heavey hammer and Big socket to straddle the rubber?
'75 CJ5 with all glass body and a 350 Chevy SB
'85 Chevy Stepside (the wife's)
'89 Volvo
All 100% maintained by me.
'70 valiant DD for my son
'74 Dart Swinger..Latest endeavor
http://home.lyse.net/brox/TonyPage4.html
