Mopar pcm for 6.4 #2605210
01/11/19 11:57 PM
01/11/19 11:57 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
I bought the mopar kit to wire my 6.4
It ran killer all summer. Now has what feels like a timing issue. Is the there a company that can test and or repair a Chrysler pcm ?
Re: Mopar pcm for 6.4 [Re: CRT] #2605212
01/12/19 12:01 AM
01/12/19 12:01 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Is there a diagnostic port that you can pull codes from? Maybe just a sensor malfunction.
Re: Mopar pcm for 6.4 [Re: CRT] #2605225
01/12/19 12:18 AM
01/12/19 12:18 AM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Yes. It's got a code for a large vacuum leak. Its popn like it has a timing issue
Re: Mopar pcm for 6.4 [Re: CRT] #2605227
01/12/19 12:26 AM
01/12/19 12:26 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
ModuleGods PCM, jeep guys are using them for the 05/06 PCM's that are failing like crazy and their stuff seems to work better than others.
https://modulegods.com/powertrain-control-module-pcm/
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Mopar pcm for 6.4 [Re: CRT] #2605313
01/12/19 09:35 AM
01/12/19 09:35 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Have you checked fuel pressure, it could be very lean causing your problems?
What code does it have?
68 Barracuda Formula S 340
Re: Mopar pcm for 6.4 [Re: CRT] #2605318
01/12/19 10:18 AM
01/12/19 10:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We have very few PCM issues that I've seen. What is the exact fault (Pxxxx?) you have?
Doug
Re: Mopar pcm for 6.4 [Re: CRT] #2605320
01/12/19 10:34 AM
01/12/19 10:34 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Fuel pressure. Lean always pops through the intake.
Re: Mopar pcm for 6.4 [Re: CRT] #2605369
01/12/19 01:52 PM
01/12/19 01:52 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Have a gage on the cowl 58 psi. Others feel it may be a valve spring. I am going to pull off the valve covers and look
Re: Mopar pcm for 6.4 [Re: CRT] #2605388
01/12/19 02:15 PM
01/12/19 02:15 PM
sgcuda Offline
sgcuda  Offline
Valve spring is a very good possibility. Haven't seen that issue on the 6.4, but the 5.7's are a regular in our shop. Runs very rough, if it runs at all. It's amazing what a broken valve spring will cause the electronics to default to. Not just a simple fix anymore. You have to think it through. If it's a plastic intake manifold, suspect a vacuum line that fell off, crack, glued in plug that fell out. Is the idle speed higher than normal? If it is, I would suspect an intake issue. If not, I would be looking at valve springs, bent pushrods, etc...
