? dana 60 axles bearings, dry or wet? #260487
03/21/09 08:54 AM
03/21/09 08:54 AM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
Do the dana axle end bearings run dry or wet.?
Have a squeak and it sounds like a dry squeak. Can I just pull axle and grease up the bearing? OR does it use the diff fluid for lubrication?
thanks
Re: ? dana 60 axles bearings, dry or wet? [Re: hemibeep] #260488
03/21/09 11:24 AM
03/21/09 11:24 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Bearings need to be packed.
Re: ? dana 60 axles bearings, dry or wet? [Re: hemibeep] #260489
03/21/09 03:39 PM
03/21/09 03:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Depends weather you have stock tapered bearings or sealed "green" type bearings
Gus
64 Plymouth Savoy
Dana 60
Re: ? dana 60 axles bearings, dry or wet? [Re: fourgearsavoy] #260490
03/21/09 09:02 PM
03/21/09 09:02 PM
According to my '70 shop manual, it shows outer AND inner seals which means THEY MUST BE PACKED
Manual says "lubricate bearings with Multi-purpose grease, NLGI grade 2 E.P. or equivalent
Re: ? dana 60 axles bearings, dry or wet? #260491
03/21/09 09:24 PM
03/21/09 09:24 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
This is taken from the Dana 60 Manual.
Re: ? dana 60 axles bearings, dry or wet? [Re: hemibeep] #260492
03/21/09 10:13 PM
03/21/09 10:13 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Truck full floater or car/truck semi floater??? Totally different animals.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: ? dana 60 axles bearings, dry or wet? [Re: gamagoat6x6] #260493
03/21/09 11:44 PM
03/21/09 11:44 PM
Snoopy Offline
Snoopy  Offline
Are you saying he can't use those instructions to repack his axle bearings?
Re: ? dana 60 axles bearings, dry or wet? [Re: Snoopy] #260494
03/21/09 11:58 PM
03/21/09 11:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not if it's a truck style full floater...
