ritter intake #2601619
01/04/19 06:35 PM
01/04/19 06:35 PM
bonney lake washington
W
w2stroker Online content OP
w2stroker  Online Content OP
W
where is a good place to buy one these days? tall 4150 version preferred
Re: ritter intake [Re: w2stroker] #2601696
01/04/19 10:08 PM
01/04/19 10:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You should check out the listings in the For Sale - Race Parts - 1st Quarter ads. I think there's at least one there (no, not my part). scope
Re: ritter intake [Re: BradH] #2601856
01/05/19 11:36 AM
01/05/19 11:36 AM
W
W
thanks for the heads up!
Re: ritter intake [Re: w2stroker] #2602325
01/06/19 04:08 AM
01/06/19 04:08 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
The tall intake is a real pita to port.
Re: ritter intake [Re: sixpackgut] #2604244
01/10/19 01:43 AM
01/10/19 01:43 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Don’t be scared and cut it in half
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: ritter intake [Re: 1967dartgt] #2604316
01/10/19 10:01 AM
01/10/19 10:01 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Yeap X2
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: ritter intake [Re: ric3xrt] #2605841
01/13/19 01:16 PM
01/13/19 01:16 PM
BradH Offline
BradH  Offline
Yeap X2
What's involved in making it a "whole" intake again?
Re: ritter intake [Re: BradH] #2606252
01/14/19 01:03 AM
01/14/19 01:03 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I’d guess a gasket equal to the blade thickness (and whatever was taken off for clean up on the mill).
Re: ritter intake [Re: WO23Coronet] #2607080
01/15/19 06:57 PM
01/15/19 06:57 PM
BradH Offline
BradH  Offline
I was thinking more along the lines of whether there needed to be a fixture to make sure the ports line up and intake manifold faces & the cylinder heads are still square. That way you'd be maintaining the previous geometry, but the welding would also need to act as a filler between the two haves, not just a welded joint.
Regardless, I'd expect a good bit of grinding to finish off the "reassembly" process, too.
Re: ritter intake [Re: w2stroker] #2607103
01/15/19 07:33 PM
01/15/19 07:33 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just noticed the threaded "tabs" welded on to each half for realignment...
Re: ritter intake [Re: burdar] #2607108
01/15/19 07:38 PM
01/15/19 07:38 PM
dogdays Offline
dogdays  Offline
JB Weld.
R.
Re: ritter intake [Re: w2stroker] #2609173
01/19/19 11:53 PM
01/19/19 11:53 PM
SoCal
Brian Hafliger Offline
SoCal
I have one Martin...
Brian Hafliger
Re: ritter intake [Re: Brian Hafliger] #2609802
01/21/19 11:44 AM
01/21/19 11:44 AM
W
W
damn! lol figures just my luck. I ordered one from kent last week frown
Re: ritter intake [Re: BradH] #2611472
01/24/19 10:35 AM
01/24/19 10:35 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Yeap X2
This one here was used a few times on the dyno, each time it was Clear RTV then bolted back together. this was also a Dry intake once the finial work was done it was tig'ed back together.
Wet intakes I'll black RTV till there are to be welded back together.
