Re: Powerglide to BB Mopar
[Re: Forest]
#2603864
01/09/19 01:27 PM
01/09/19 01:27 PM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
The JW spacer you mention...is that the converter hub adapter for a GM converter to Mopar crank? The Meziere goes on the trans side of the flexpate so it doesn't space the flexplate out. How does the starter situation look?
The JW spacer goes between the Mopar crank and the JW flexplate and spaces the flexplate out toward the trans. We had to make a 3/16 spacer for the starter or it would be engaged all the time.
[Re: cl440]
#2603866
01/09/19 01:33 PM
01/09/19 01:33 PM
Posts: 4,675 On the parachute mount
n20mstr
I have the JW wheel, adap, bell on a T400. Same situation , I had the pads on the converter knocked down .100. Also took .100 of the part of the spacer that sticks thru the flywheel. After machining it was flush with the flywheel so it still registered it.
....BAD A$$ STREET CAR.....
[Re: dafixr]
#2603867
01/09/19 01:34 PM
01/09/19 01:34 PM
cl440
S.E. Michigan
On ours we machined the spacer down for additional clearance,also we adjusted the starter depth with shims on starter.
Good luck We thought about that option also. We would just have to make additional spacers for the starter since this would move the flexplate closer.
[Re: n20mstr]
#2603868
01/09/19 01:35 PM
01/09/19 01:35 PM
cl440
S.E. Michigan
I have the JW wheel, adap, bell on a T400. I had the pads on the converter knocked down .100 That is another option we are looking at. That would give us the clearance we need
[Re: cl440]
#2603869
01/09/19 01:37 PM
01/09/19 01:37 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I had the same issue when I put a 2004 in my '68 A-Body. I sent the converter back and they altered the thickness of the converter to gain the clearance I needed. I didn't use a crank spacer or mid-plate.
The Reid bellhousing install is much cleaner and easier to work around than using an adapter plate.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: cl440]
#2603882
01/09/19 01:58 PM
01/09/19 01:58 PM
Posts: 916 SE Washington
Forest
SE Washington
The JW spacer goes between the Mopar crank and the JW flexplate and spaces the flexplate out toward the trans. We had to make a 3/16 spacer for the starter or it would be engaged all the time. Gotcha, sucks we cant do this swap easily... 1/4 aluminum midplate?
[Re: cl440]
#2603889
01/09/19 02:10 PM
01/09/19 02:10 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
When you source parts from different manufacturers, this happens. It's not a screw up by anyone, just typical non-Chevy race car headaches. I always specified a standard dimension converter and did what I had to do with the small parts to make it work. Helps avoid any future issues with converters.
[Re: CMcAllister]
#2603935
01/09/19 03:35 PM
01/09/19 03:35 PM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
When you source parts from different manufacturers, this happens. It's not a screw up by anyone, just typical non-Chevy race car headaches. I always specified a standard dimension converter and did what I had to do with the small parts to make it work. Helps avoid any future issues with converters. I worked at a shop that was mainly Chevy. Once you get past OEM style parts, Chevys didn't bolt together either. Also, it seemed like the more the part cost, the more work it needed to fit.
