Welding in frame stiffeners
#2603643
01/08/19 11:16 PM
01/08/19 11:16 PM
Posts: 1,487 STL
cdstl
STL
A buddy is going to weld in the full US Cartool stiffening kit into a 71 Demon. He wants to put it on a rotisserie to do it so the the welds will go in better. Plus it's easier than laying on your back.
I thought that I had read the it's best to have the car on all fours to weld in the frame connectors.
Any opinions?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Welding in frame stiffeners
[Re: AndyF]
#2603700
01/09/19 01:16 AM
01/09/19 01:16 AM
RapidRobert
decades ago a local guy had em done & he said the guy jacked the car up in the middle of the stiffeners then finished welding em in (that is all I remember (fwiw). Not my area at all but off the top of my head I would want it completely loaded & up on all fours then weld em. EDIT he said he "slightly" jacked em up in the middle of their length then finish welded.
[Re: cdstl]
#2603826
01/09/19 12:05 PM
01/09/19 12:05 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
I X braced my door jams & X braced the inside of the car from side to side also before I put it up on my rotisserie. I was going for the sleeper look so I hid my frame connectors inside the rocker panels.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: cdstl]
#2603843
01/09/19 12:41 PM
01/09/19 12:41 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
We installed the ones on Dads 72 Duster using the stock suspension and the car setting up in the air with all of the weight on the suspension. I left the wheels and tires on the car and used eight wheels 4 14" and 4 15"...It might look like he!! but it was very stable and worked out well... If you get it up high enough it isn't a bad job at all...The doors on his car close just like they did in 72 and never needed adjusted. I'd install them again this way if I have to... As mentioned above it does help to have something a little heavy to set in on the floor pan and help close the gap to the frame connectors when welding to the floor pan...Mine fit very well once mocked up... Maybe next time I can use the 4 post lift...
...FAFO...
