Page 1 of 3 1 2 3
727 Transbrake valve body #2602318
01/06/19 03:03 AM
01/06/19 03:03 AM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
I’m looking for product recommendations for a 727 Transbrake valve body. The car is a ‘70 Dart, low eleven second, Pro class bracket racer.
I’ve found ATI with an A and A brake from them for $750. TCI from Jegs for about $850 and the new Turboaction XA model for $900 from Summit. I don’t think Turbo makes the older version any longer.
Any suggestions would be appreciated.
I also plan to go with some kind of adjustable button like the Just-n-time or a Biondo
Thanks guys
Jeff
Re: 727 Transbrake valve body [Re: jinxy] #2602320
01/06/19 03:14 AM
01/06/19 03:14 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
TranzAct of Indy has his own too might check him out, there is an ad at the top on occasion.
eBay-cdwmotorsports
Re: 727 Transbrake valve body [Re: cdwmotorsports] #2602321
01/06/19 03:28 AM
01/06/19 03:28 AM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
Thanks I’ll check them out
Re: 727 Transbrake valve body [Re: jinxy] #2602352
01/06/19 10:18 AM
01/06/19 10:18 AM
tboomer Offline
tboomer  Offline
Check with John Cope. He is a board sponsor and can help you with your needs.
http://coperacingtrans.com/
Re: 727 Transbrake valve body [Re: jinxy] #2602408
01/06/19 01:56 PM
01/06/19 01:56 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
x2 on cope
Re: 727 Transbrake valve body [Re: jinxy] #2602411
01/06/19 02:06 PM
01/06/19 02:06 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tranzact of Indy makes the TCI brake...I have 5 of transbrakes from Tranzact in use with the oldest one dating back to 1993. Just bought the 5th one a few months ago and talking with Joe he said if I needed it now it was going to say TCI on it cause he was producing a batch for,
Tony
70 AARCuda Vitamin C
Re: 727 Transbrake valve body [Re: 70AARcuda] #2602529
01/06/19 06:34 PM
01/06/19 06:34 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
Nice! up
Re: 727 Transbrake valve body [Re: a493demon] #2602540
01/06/19 06:58 PM
01/06/19 06:58 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By a493demon
x2 on cope
X3 love mine up
Re: 727 Transbrake valve body [Re: jinxy] #2602747
01/07/19 02:13 AM
01/07/19 02:13 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Re: 727 Transbrake valve body [Re: 70AARcuda] #2602761
01/07/19 02:37 AM
01/07/19 02:37 AM
Martinsville, IN
Martinsville, IN
Tony I presume your 1993 is an external brake like mine? I talked to Joe a month or so back and he laughed and said we need to get that updated.
eBay-cdwmotorsports
Re: 727 Transbrake valve body [Re: jinxy] #2602762
01/07/19 02:38 AM
01/07/19 02:38 AM
Martinsville, IN
Martinsville, IN
Just a side note to the OP, notice the three companies being discussed used are all Indiana trans builders.
https://www.tranzactracing.com
eBay-cdwmotorsports
Re: 727 Transbrake valve body [Re: cdwmotorsports] #2602776
01/07/19 03:19 AM
01/07/19 03:19 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
NO...it is an internal brake...just it is cast aluminum instead of the newer billet ones. It is currently in a 904 behind a 408. We had a problem with the trans a few years back and I wondered if it was the brake..and called Joe. He said the warranty had expired.LOL..but it was not the transbrake.
Tony
Re: 727 Transbrake valve body [Re: jinxy] #2602811
01/07/19 10:09 AM
01/07/19 10:09 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I would say more importantly that I know that Cope and Trazact are a phone call away with any questions you might have or more importantly, changes to the trans that may benefit the use of the brake.
FWIW I use a Pro Trans trans brake. They build them in house and Dave and Darren have been good to me. They were fairly local to me, but unfortunately they’ve pulled up stakes from commiefornia and are currently relocating to Texas.
Re: 727 Transbrake valve body [Re: jinxy] #2603102
01/07/19 09:02 PM
01/07/19 09:02 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
That CRT looks super nice. Can I change out the low/reverse servo in car?
Re: 727 Transbrake valve body [Re: jinxy] #2603463
01/08/19 03:40 PM
01/08/19 03:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The L/R servo “can” be serviced in the car. Requires removing the keeper tab from the tail shaft (cutting) to allow the pin to slide out far enough to remove the linkage for the band. You then can get creative with a bottle jack and large socket to get the piston compressed enough to remove the snap ring and allow piston removal. Be aware that you’ll have to have patients to get the band linkage back in place. Way easier on a bench, than under the car for sure. You can make a tab for the cross pin and secure it with one of the tail shaft bolts.
Re: 727 Transbrake valve body [Re: jinxy] #2603475
01/08/19 04:22 PM
01/08/19 04:22 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
The trans was done 100 passes ago street/strip build with Turboaction reverse manual valve body and works great no issues. Would it be sudden death if I put the Transbrake on it without the new servo?
Re: 727 Transbrake valve body [Re: jinxy] #2603489
01/08/19 04:47 PM
01/08/19 04:47 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I would consult the person you’re buying the t-brake from. Another “factor” I’d strongly consider is plugging the front vent and relocating it to the rear. This will obviously require trans removal.
Re: 727 Transbrake valve body [Re: J_BODY] #2603568
01/08/19 07:33 PM
01/08/19 07:33 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
Agreed thanks
Re: 727 Transbrake valve body [Re: J_BODY] #2603570
01/08/19 07:48 PM
01/08/19 07:48 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Easier than that, simply back off the adjuster and the band link can be removed allowing the lever to drop free.
Re: 727 Transbrake valve body [Re: jinxy] #2603680
01/09/19 12:21 AM
01/09/19 12:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Thanks for the clarification John.... I was thinking the linkage had to be removed for the servo to clear.
Page 1 of 3 1 2 3
