Does your front cover for a Big Block accept a stock seal(yes it does), AND can it be made to accept the seal that comes in a Jesel Belt drive?
The reason I ask is , im cheap, and the stock seal gives up at 10-13" of pan vac, not allowing a lot of pan vac.
I know eventually im going to just buy the Jesel Belt drive, but I figured I would ask
N20mstr, I believe i am even cheaper then you. LOL I filled in the back side of the seal with RTV and let it dry before putting it on. I idle with 12 inches and launch with 16. This is using a old Moroso 3 vane pump (not the enhanced) .
I do use a one piece seal for the rear.
edit: thinking about it, this seal may have 2 springs (old and new) and the RTV.
Joe
