Cleaning Cometic head gaskets #260289
03/20/09 09:33 PM
03/20/09 09:33 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Is it OK to use carb cleaner, brake cleaner, etc to clean the copper coat off of Cometics? Id think it would be OK, but want to make sure.
Also, I sprayed copper coat between the layers. Drill the rivets out and clean? Is that OK? Do I need to rerivet them or no?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Cleaning Cometic head gaskets [Re: Von] #260290
03/20/09 09:44 PM
03/20/09 09:44 PM
i use laquer thinner. no need to rivet them again. the dowels will hold them in place.
Re: Cleaning Cometic head gaskets [Re: Von] #260291
03/20/09 09:45 PM
03/20/09 09:45 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I was told to use laquer thinner to clean. Don't see any problem with taking layers apart as long as they are put back in same order with or without the rivet added
Re: Cleaning Cometic head gaskets [Re: wheelsup68dart] #260292
03/20/09 10:13 PM
03/20/09 10:13 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Lacquer thinner it is.
Thanks guys.
Re: Cleaning Cometic head gaskets [Re: Von] #260293
03/20/09 11:09 PM
03/20/09 11:09 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Thanks guys.
yeah, dont use the brake clean
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Cleaning Cometic head gaskets [Re: Stroker Scamp] #260294
03/21/09 04:59 AM
03/21/09 04:59 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
why not use the brake clean? thats all i've ever used & it cleans so well. the last set of cometics lasted 9 re-uses before they leaked, if i used laquer thinners do you think i would have gotten more?
