Cleaning Cometic head gaskets
#260289
03/20/09 09:33 PM
03/20/09 09:33 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Is it OK to use carb cleaner, brake cleaner, etc to clean the copper coat off of Cometics? Id think it would be OK, but want to make sure.
Also, I sprayed copper coat between the layers. Drill the rivets out and clean? Is that OK? Do I need to rerivet them or no?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Cleaning Cometic head gaskets
[Re: Von]
#260290
03/20/09 09:44 PM
03/20/09 09:44 PM
i use laquer thinner. no need to rivet them again. the dowels will hold them in place.
[Re: wheelsup68dart]
#260292
03/20/09 10:13 PM
03/20/09 10:13 PM
Von
NE Oklahoma
Lacquer thinner it is. Thanks guys.
