Sonic Bore testing in OHIO #2602853
01/07/19 12:31 PM
01/07/19 12:31 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I live near Columbus Ohio an want to have my 440 block bores sonic tested. I have done internet searches and come up blank. Anyone know where I can get sonic testing local?
Re: Sonic Bore testing in OHIO [Re: mopfried] #2602893
01/07/19 01:26 PM
01/07/19 01:26 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Whatever machine shop you plan to use should be able to sonic test it.
Re: Sonic Bore testing in OHIO [Re: fbs63] #2602922
01/07/19 02:23 PM
01/07/19 02:23 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Thanks. I will give them a call.
Re: Sonic Bore testing in OHIO [Re: mopfried] #2602930
01/07/19 02:29 PM
01/07/19 02:29 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
And if they can't perform a sonic test - move on to the next one
Re: Sonic Bore testing in OHIO [Re: mopfried] #2602934
01/07/19 02:31 PM
01/07/19 02:31 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Fowler engine over by the John Glenn airport is where I had my done
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Sonic Bore testing in OHIO [Re: mopfried] #2602935
01/07/19 02:32 PM
01/07/19 02:32 PM
an8sec70cuda Offline
I think some of yall take for granted just how few people use sonic testers anymore.
I found ONE machine shop/engine builder in the state who had one after calling a bunch of em. PAR, Gene Fulton, Buck, and several other well known local shops did not have one.
Found one at a builder that does a lot of roundy round engines, said he rarely uses it on stock cast heads.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Sonic Bore testing in OHIO [Re: mopfried] #2602944
01/07/19 02:44 PM
01/07/19 02:44 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I called Fowler. clean, sonic check, bore and finish hone right at $475
Re: Sonic Bore testing in OHIO [Re: mopfried] #2603133
01/07/19 10:19 PM
01/07/19 10:19 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Call Doug Mann in Newark Oh at Mann performance and talk to him 740-404-4204 tell him Bill Hart sent you. up
Re: Sonic Bore testing in OHIO [Re: mopfried] #2603168
01/07/19 11:17 PM
01/07/19 11:17 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
FYI- I had Fowler do some work on an intake for me a few years ago; just had them open up a stock intake with a vertical mill. They were easy to deal with and reasonably priced.
