HP Loss by Lowering Compression??
#730915
06/21/10 11:23 PM
06/21/10 11:23 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I was wondering how much Hp you think a motor would lose by lowering the compression by a couple of points. I currently have a 13.5 - 1 512 with cnc ported max wedge Indy SRs. The motor made 800 Hp and 710 torque. I live in Canada and our wonderful government is making purchasing race fuel a difficult proposition. Plus the cost is to buy it is sky rocketing. A buddy just bought a barrel and it was almost 900.00. This is crazy!!! I am thinking that pump gas is the way to go! I have raced a lot of Super Street in the past and the car with the current set up will run 10.90 at 135 - 137. It is plenty fast but wondering what you think it would do with 11.5 rather than 13.5
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
Re: HP Loss by Lowering Compression??
[Re: 451Guy]
#730917
06/21/10 11:38 PM
06/21/10 11:38 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Does Canada offer E85 fuel yet If so convert to that instead of lowering the comression Or maybe convert to straight Ethanol fuel if it is cheaper than race gas like here in the states
[Re: Cab_Burge]
#730918
06/21/10 11:43 PM
06/21/10 11:43 PM
451Guy
Alberta, Canada
Thanks Guys - So far no E-85. Not sure the Oil tycoons in this neck of the woods are all that fond of veggie power. I had considered the alcohol route but was unsure of all that was involved and have heard lots of "horror stories" about milk shake oil, draining carbs at night, water in the fuel etc. Pump Gas just seems simpler.
Thanx 451 Guy
[Re: 451Guy]
#730919
06/21/10 11:47 PM
06/21/10 11:47 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
13.5:1 at your elevation I would not hesitate to run 100LL AvGas. You will hear many opinions on this, however, I can state having no issues with 100LL at that compression ratio running in Alberta. I certainly do not want to start another AvGas thread but thought you should take it into consideration before lowering CR of the motor.
76 Duster
work in progress
[Re: Edge]
#730920
06/22/10 12:00 AM
06/22/10 12:00 AM
451Guy
Alberta, Canada
Edge - That's a thought! Had not considered Av Gas. I may have to consider that.
Have you got your motor done yet??
Thanx 451 Guy
[Re: 451Guy]
#730921
06/22/10 12:15 AM
06/22/10 12:15 AM
Edge
Alberta Canada
B1 Motor is finished, looks nice but headers not finished yet so we have not made any noise yet, car is currently getting a full moly 25.5 chassis with four link and strut front end, decided the ladder bar back half would be to much of a handful on some of our tracks so will have to wait till next season
76 Duster
work in progress
[Re: Edge]
#730922
06/22/10 12:25 AM
06/22/10 12:25 AM
451Guy
Alberta, Canada
Looking good. When its is all done you will have to bring it to Castrol. I think there were 50 A body mopars at the track on Sunday and only 2 early generation Camaros. Never thought I would see the day. I remember when my Demon was different! Not any more. Build Looks really good! Looking forward to seeing it in person. Good luck with the build.
Thanx 451 Guy
[Re: 451Guy]
#730923
06/22/10 08:22 AM
06/22/10 08:22 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Probably about 30 hp max and with aluminum heads.Ypu might loose .1 in the quarter at full power and you will be able to run 94 with 255 ish @ .050 cam. Cylinder pressure is the key keep cranking below 200 and 94 should be fine. That is all I have ran for 9 years since I got Indy heads. My old motor ran for 5 years with 195 low and 204 high cranking on 94. 263 @ .050 flat tappet 11.7 to 1 compression. This one is 11.5 to one with 272 roller thinking of going to 91 once I get rings broke in I'll check my cranking but can't see it going past 170. Old 540 RIP had a 274 @ .050 roller and 11.6 to one and was fine on 94 only about 165 cranking and it never blinked on 94 even in 40 F sea level air (5 C in french) too bad the balancer failed and gutted the engine (my fault long story )
[Re: 451Guy]
#730928
06/22/10 08:21 PM
06/22/10 08:21 PM
Posts: 16,928 NC
440Jim
NC
My cam is 272 Intake and 280 Exhaust at 50. Wondering if you think this would work?
I was going to say 6% loss from 13.5 to 11.5 CR. But your cam doesn't have a lot of duration, so maybe only 5% loss of power.
The big issue with race alky (methanol) is the right carb and tune, and leaning the engine to put heat in the water/oil. If tuned and operated right, methanol is not a big problem. I like my mechanical injection (Ron's), and they offer a primer and idle system (primer plus) that allows you to start and put heat in the motor before the pass, and driving back to the pits on pump gas (yes 87 octane, no load).
$900/barrel is about $16/gallon. You would be money ahead switching to alcohol. And it would be better.
I am running 13.5 CR, and 279/287 at 0.050" cam, with 4.250" stroke.
[Re: 440Jim]
#730929
06/23/10 02:17 PM
06/23/10 02:17 PM
451Guy
Alberta, Canada
Thanks guys for your replys. It would appear that the power loss would not be significant. As I had said I am already way faster than I need to be to run my class. Jim the alcohol thing is interesting. I was checking out Rons Web site and they make it look easy. I guess I will see. Has anyone had any experience with the snow performance system that injects ethanol into the engine?
Thanx 451 Guy
[Re: 451Guy]
#2602661
01/06/19 11:23 PM
01/06/19 11:23 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
check the prices of avgas, its a good option but not always cheap...airports set their own prices usually and if they have a monopoly the price is typically 15-25% higher so shop around. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 451Guy]
#2602673
01/06/19 11:37 PM
01/06/19 11:37 PM
Cab_Burge
On your deal lowering the compression to under 11.0 to 1 would be what I would do My old 518 C.I. low deck stroker motor(10.78 to 1 comp ratio) with a set of Indy SR M.W heads pump gas Duster that weighed 3450Lbs with me in it ran 9.993 at 134.+ MPH in the 1/4 through the full 3.0 inch exhaust system on the car with the 16x3 inch tall air cleaner on using the local 91 octane pump fuel That motor made 727 HP at 6500 RPM with a single 1050 CFM Dominator carb on the stock early cast Indy 400-3 intake manifold in Klamath Falls, OR at 4300 Ft altitude on a stingy DTS engine dyno, no all out trick race parts at all I run pump E85 on my current bracket car, I love it and so does the engine
[Re: 451Guy]
#2602765
01/07/19 02:53 AM
01/07/19 02:53 AM
Posts: 712 Southern Alberta
Uberpube
Southern Alberta
Thanks Guys - So far no E-85. Not sure the Oil tycoons in this neck of the woods are all that fond of veggie power. I had considered the alcohol route but was unsure of all that was involved and have heard lots of "horror stories" about milk shake oil, draining carbs at night, water in the fuel etc. Pump Gas just seems simpler. Where are you in Alberta? There is a gas station on 17th ave sw in Calgary that sells E-85 now. https://gbfuels.biz/home/e85/
