Aluminum water pump #2601485
01/04/19 02:36 PM
01/04/19 02:36 PM
69cornetr/t
69cornetr/t
Who makes reliable aluminum water pumps and housings?
There is so much junk out there sold by big name companies I don't want to end of with something that doesn't fit right or fail in 6 months
Thanks for any input
Re: Aluminum water pump [Re: ] #2601489
01/04/19 02:47 PM
01/04/19 02:47 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
BB or SB?
Re: Aluminum water pump [Re: ] #2601491
01/04/19 02:53 PM
01/04/19 02:53 PM
69cornetr/t
69cornetr/t
Re: Aluminum water pump [Re: ] #2601503
01/04/19 03:07 PM
01/04/19 03:07 PM
AndyF Offline
AndyF  Offline
The housing is a simple casting with no moving parts so hard to go wrong there. If I was buying a new one I'd probably get one from Mancini Racing just because I deal with those guys a lot.
The water pump is going to be a crap shoot. I usually prefer brand names on stuff like that but there is no guarantee that any pump will last a long time. I've had Edelbrock pumps fail quickly and I've had them last for years. Once again, I'd probably just buy a pump from Mancini on the theory that they sell a lot of them so they know which vendor is good and which isn't.
If you aren't super concerned with weight you can get cast iron water pumps really cheap from Summit.
Re: Aluminum water pump [Re: ] #2601514
01/04/19 03:28 PM
01/04/19 03:28 PM
69cornetr/t
69cornetr/t
I've seen cast aluminum from 60 to 350 so that's got me wondering 60 bucks there has to be something wrong there
Re: Aluminum water pump [Re: ] #2601523
01/04/19 03:47 PM
01/04/19 03:47 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
I've used edelbrock, MP, and also a few 20 dollar parts store pumps and they all worked great.
I haven't found a housing that I like quite as much as the MP one which is no longer produced, or the stock iron ones.
don't know about electric....
Rich H.
Esse Quam Videri
Re: Aluminum water pump [Re: ] #2601533
01/04/19 03:57 PM
01/04/19 03:57 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Only $53 shipped to your door. They were $40 a few months ago.
https://www.ebay.com/itm/Chrysler-Mopar-BB-360-383-440-High-Volume-Aluminum-Water-Pump-Housing-Ony/291748195503?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
69 GTX 68 Road Runner
Re: Aluminum water pump [Re: ] #2601537
01/04/19 03:59 PM
01/04/19 03:59 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the housings are pretty much all cast in the same place these days. check for casting flash inside and make sure all the opening are there. may have to grind the open to allow proper flow.
on the water pumps, I always run the mylodon high volume pump. been around forever works well. flow kooler makes another style of pump that supposed to work well. i'd stay away from any of the pumps with a cast impeller
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Aluminum water pump [Re: Jerry] #2601554
01/04/19 04:17 PM
01/04/19 04:17 PM
69cornetr/t
69cornetr/t
Thanks everyone!
Re: Aluminum water pump [Re: ] #2601566
01/04/19 04:26 PM
01/04/19 04:26 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've used a 440 source housing and pump on my car for the last 8 years without any issues.
Re: Aluminum water pump [Re: DusterKid] #2601636
01/04/19 07:31 PM
01/04/19 07:31 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, mine has been on two different engines (blew up a 440, no fault of the wp) for well over 5700 miles and 4 years. Never any issues with the 440Source pump, housing or thermostat housing.
Re: Aluminum water pump [Re: ] #2601723
01/04/19 11:10 PM
01/04/19 11:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
My MoPar RB housing had quite a bit of casting flash and raw machined edges in the water path, I blended them in for peace of mind. I was also not impressed with how far away the impeller blades were from the housing inner surface, milling a bit off the forward mating surface would make that closer but I never did.
Boffin Emeritus
Re: Aluminum water pump [Re: polyspheric] #2601730
01/04/19 11:21 PM
01/04/19 11:21 PM
In my exp w pumps are as dependable as any part I have ever dealt with. I would cut a disc in half & weld it behind the blades (on a BB pump) for an anticav plate & get a pump with the most vanes. What Poly said, you want the impeller to housing clearance as minimal as possible (.040") & for sure check/port/deburr the housing (as needed). & adequate pulley ratio
Re: Aluminum water pump [Re: ] #2601869
01/05/19 12:37 PM
01/05/19 12:37 PM
69cornetr/t
69cornetr/t
Good idea
Re: Aluminum water pump [Re: ] #2601990
01/05/19 06:11 PM
01/05/19 06:11 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Whats the diff in weight between the iron water pump and the alum one ? ... NOT talking about the housing. The last time I looked there was a H U G E price diff.
Re: Aluminum water pump [Re: ] #2601997
01/05/19 06:23 PM
01/05/19 06:23 PM
AndyF Offline
AndyF  Offline
Not a huge difference on the pump, I think it is 2 or 3 lbs. The difference on the housing is much larger.
Re: Aluminum water pump [Re: ] #2602039
01/05/19 07:50 PM
01/05/19 07:50 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
8 pound savings on the housing. Not even sure there is even a full pound difference on the pump itself.
Re: Aluminum water pump [Re: ] #2602308
01/06/19 02:43 AM
01/06/19 02:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Have bought all of mine from Mancini. Ron
Re: Aluminum water pump [Re: 383man] #2602339
01/06/19 06:06 AM
01/06/19 06:06 AM
N96 D21
torqueflite Offline
torqueflite  Offline
N96 D21
Mancini ..the hi flow one with the anti cavitation plate
Re: Aluminum water pump [Re: ] #2602385
01/06/19 01:09 PM
01/06/19 01:09 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I also have the 440source one and a Mezeri water pump
eBay-cdwmotorsports
