1965 Torqueflite check ball question #2599853
01/01/19 02:26 PM
01/01/19 02:26 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
I'm overhauling a very early model 727(1965). When I removed the valve body from the case a loose check ball fell out. I cannot find where to re-install it before I finish button up the trans....somebody, please help me. And yes the trans has a rear pump.
Re: 1965 Torqueflite check ball question [Re: marvo451] #2599882
01/01/19 02:43 PM
01/01/19 02:43 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A large check ball is used between the output shaft and rear pump gear. That is what I would check, but not sure why it would have fallen out?
Re: 1965 Torqueflite check ball question [Re: marvo451] #2599917
01/01/19 03:16 PM
01/01/19 03:16 PM
A727Tflite Offline
A727Tflite  Offline
If only the valve body was removed check and see if the manual lever detent ball became dislodged. The shift lever will have no detent feel to it if it fell out.
Re: 1965 Torqueflite check ball question [Re: marvo451] #2599939
01/01/19 03:44 PM
01/01/19 03:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What is the diameter of the ball?
Re: 1965 Torqueflite check ball question [Re: John_Kunkel] #2599957
01/01/19 04:11 PM
01/01/19 04:11 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
The diameter is 0.340. I found a second on on the work table and it is 0.245....but I believe this is from another project. When this is resolved, I will need the part number shift shaft seal for the early model valve body, also. Thank you VERY much for your help!!
Re: 1965 Torqueflite check ball question [Re: marvo451] #2600033
01/01/19 06:36 PM
01/01/19 06:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In a '65 the 11/32" ball is used on the rooster comb detent and as a check ball inside the valve body. If it was found outside the valve body it's likely the detent ball.
P/N for the shaft seal is 2466548.
Re: 1965 Torqueflite check ball question [Re: John_Kunkel] #2600403
01/02/19 01:20 PM
01/02/19 01:20 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
The check ball is in the rooster comb........it's a mystery to me. Can you cross the Chrysler part number over to Timken or National as the local Dodge dealer looks at me like I've got a third eye when I give him the Mopar number. Everywhere I look has the Timken 8609 seal listed for the much larger shift shaft,
Re: 1965 Torqueflite check ball question [Re: marvo451] #2600441
01/02/19 02:38 PM
01/02/19 02:38 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
The part# John gave crosses to this Napa part number
Re: 1965 Torqueflite check ball question [Re: Leigh] #2600981
01/03/19 03:20 PM
01/03/19 03:20 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Does this help? Seen this in my torqueflight manual. Also read the older ones used a ball key to drive the rear pump rotor.
Re: 1965 Torqueflite check ball question [Re: ratroaster] #2601059
01/03/19 06:36 PM
01/03/19 06:36 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Thanks ratroaster, but the check ball was loose when I removed the valve body from the case. It fell out when I removed the pan and was about to remove the entire valve body assembly.
Re: 1965 Torqueflite check ball question [Re: marvo451] #2601079
01/03/19 07:16 PM
01/03/19 07:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It probably got dropped in the trans at the last overhaul when the case was upside down.
The only two loose 11/32" balls in a '65 are those already mentioned but there are some staked into the reaction shaft support and the rear pump housing. Check to see if one of those popped out.
Re: 1965 Torqueflite check ball question [Re: John_Kunkel] #2601119
01/03/19 08:28 PM
01/03/19 08:28 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
OOPS..... the transmission is together. I wonder if it is even possible for the one from the rear pump to get into the interior of the transmission. I think I'll stick to much later models in the future. When I got this one it was a basket case and missing the front pump.
Re: 1965 Torqueflite check ball question [Re: marvo451] #2601128
01/03/19 08:44 PM
01/03/19 08:44 PM
A727Tflite Offline
A727Tflite  Offline
The rear pump drive ball is much smaller than the one you have loose.
Re: 1965 Torqueflite check ball question [Re: A727Tflite] #2601613
01/04/19 06:20 PM
01/04/19 06:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I was referring to the check ball inside the pump cover, never seen one pop out but............
Re: 1965 Torqueflite check ball question [Re: 451Mopar] #2601657
01/04/19 08:28 PM
01/04/19 08:28 PM
A727Tflite Offline
A727Tflite  Offline
My post regarding the size of the ball used to drive the rear pump rotor was aimed at this post.
Re: 1965 Torqueflite check ball question [Re: A727Tflite] #2601794
01/05/19 02:00 AM
01/05/19 02:00 AM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
It would be great if I could find a picture or diagram showing the relationship of this ball within the rear pump.
Re: 1965 Torqueflite check ball question [Re: marvo451] #2601830
01/05/19 06:37 AM
01/05/19 06:37 AM
A727Tflite Offline
A727Tflite  Offline
Look at John’s last post - at 5 O’clock is a radiused groove - that’s where the ball engages the rotor. The output shaft has a radiused recess where the ball sets.
A dab of grease holds the ball while you lower the output shaft into the govorner support.
Re: 1965 Torqueflite check ball question [Re: marvo451] #2601940
01/05/19 03:45 PM
01/05/19 03:45 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Thank you VERY much, John Kunkel and Transman as well as several others. The mystery is solved. It was the drive ball for the rear pump. How it got out and into the trans pan is not known. Someone before me must have bee inside before I got it. Thanks again!!!
Re: 1965 Torqueflite check ball question [Re: marvo451] #2601980
01/05/19 05:45 PM
01/05/19 05:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
But, as stated earlier, the pump drive ball is 1/4" (.250"), you said the loose ball was .343". confused
Re: 1965 Torqueflite check ball question [Re: marvo451] #2602059
01/05/19 08:37 PM
01/05/19 08:37 PM
A727Tflite Offline
A727Tflite  Offline
“i’m Really confused now”.
