Re: Which auto trans is in a 97 Ram 5.9 Magnum?
[Re: poorboy]
#2600086
01/01/19 08:25 PM
01/01/19 08:25 PM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: poorboy]
#2600326
01/02/19 08:00 AM
01/02/19 08:00 AM
Posts: 5,785 ohio
ruderunner
ohio
Shifter still controlled PRND21, overdrive controlled by the computer. Switch was to lock out od.
Any 904 or 727 shifter will work. Only need a switch to turn off od when you want, can be on shifter or dash or...
Angry white pureblood male
[Re: ruderunner]
#2600409
01/02/19 01:32 PM
01/02/19 01:32 PM
Posts: 3,042 N.W. Florida
Fat_Mike
N.W. Florida
Any 904 or 727 shifter will work. Only need a switch to turn off od when you want, can be on shifter or dash or... ...and if you don't use it to tow (often or long distances), I can't think of any reason you'd want to turn it off.
[Re: poorboy]
#2601209
01/03/19 11:34 PM
01/03/19 11:34 PM
Posts: 10,543 Freeport IL USA
poorboy
Freeport IL USA
What do I need to do with the converter lockup? Shouldn't the factory computer take care of that?
This truck has a 91 Dakota chassis, a 360 Magnum, the 46re trans, a 9 1/4 (70s version) with 3:23 gears, a small 39-47 cab, hood, grill shell, and a 6'6" Dakota box floor with the 39-47 sides. Essentially its a Dakota RT with about a 1,000 less lbs. The little I've driven it leads one to believe its going to have plenty of power for the way this old man drives. Here are the most recent pictures I have of the truck, at the paint shop. Gene
[Re: poorboy]
#2601835
01/05/19 08:55 AM
01/05/19 08:55 AM
Posts: 5,785 ohio
ruderunner
ohio
Sounds like a fun build. But I think you may have caused a problem using the 70s rear axle.
I think the 97 ecm used the speed sensor on the rear axle to control overdrive which the 70s axle doesn't have.
A 91 Dakota ecm would have used a speed sensor on the tail shaft of the transmission. And the 91 Dakota axle would have a rear axle sensor for abs.
Where are you picking up the vehicle speed reading?
[Re: ruderunner]
#2601982
01/05/19 05:52 PM
01/05/19 05:52 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'98 was the year they moved the speedo input to the rear end.
[Re: poorboy]
#2602050
01/05/19 08:03 PM
01/05/19 08:03 PM
Posts: 5,785 ohio
ruderunner
ohio
Ok, I was off a year. So that changed with the re designation then?
[Re: ruderunner]
#2602518
01/06/19 06:11 PM
01/06/19 06:11 PM
John_Kunkel
Rio Linda, CA
The RE (Rear drive Electronic) designation started in '96, prior to that it was RH (Rear drive Hydraulic).
