Re: Where to put brake splitter on super narrow axle?
[Re: radar]
#2600703
01/02/19 11:26 PM
01/02/19 11:26 PM
Posts: 11,714 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Split it on the chassis. Run individual lines on the framerails to both sides of the frame. Weld tabs with connectors for hoses on each side and connect them. Make hoses from connector to caliper on each side. That's how most tube cars with really busy housings are done.
