383 rear main seal leak?
#2599703
01/01/19 11:08 AM
01/01/19 11:08 AM
Posts: 1,177 Woodbridge
Tommy The Chryco
Woodbridge
so, just rebuilt and now my rear main seal is leaking....badly enough that it needs to be repaired. so what is the best seal to use? can I try to correct this leak while the motor remains in the car? I have to remove the transmission anyways so is it best I do it then? really frustrated with this motor. Any thoughts or direction is greatly appreciated.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 383 rear main seal leak?
[Re: Tommy The Chryco]
#2599788
01/01/19 01:26 PM
01/01/19 01:26 PM
Posts: 2,260 IL
furious70
IL
Per some other's suggestions more than a decade ago I was able to roll a factory seal out and roll a new rope seal in with everything in the car. It was leaking bad enough that it would drip on the ground several times a minute. These days it doesn't leak any worse than the average big block. I probably got lucky.
70 Sport Fury 68 Charger 69 Coronet 72 RR
#2600261
01/02/19 01:21 AM
01/02/19 01:21 AM
Posts: 43,295 Bend,OR USA
Cab_Burge
I'm in the middle of trying one of 440 Source Viton rear main seal on a motor I'm having issues on sealing the rear main seal ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) I haven't had one leak in a lot of years and now I've had several motors leak ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) I may have a issue with the new batch of 10 rear main seals I bought earlier this year being bad I'll know more tomorrow on if this is a good fix or not after running on the engine run stand, I'll post my results ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
#2600771
01/03/19 01:50 AM
01/03/19 01:50 AM
Posts: 712 California
BigDaddy440
California
When it comes to rear main leaks, I've had better luck using the newer CNC aluminum rear main seal retainers, over the OEM retainer.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: DrCharles]
#2601299
01/04/19 01:50 AM
01/04/19 01:50 AM
Cab_Burge
The 400 Source brown Viton rear seals fixed my leak Is that the low-deck division of 440 Source? I do use a sealer, Permatex adhesive sealant only, on the sides of the seal holder In addition to the "strips" or pipe cleaners, or just the sealant by itself? Oops, it pays to proof read ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) For those that don't know, the seam size rear main seal fits all the B,RB and Gen 2 426 Hemi motors I do use the side seals ALWAYS along with the sealant ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
