383 rear main seal leak? #2599703
01/01/19 11:08 AM
01/01/19 11:08 AM
Woodbridge
Tommy The Chryco Offline OP
Woodbridge
so, just rebuilt and now my rear main seal is leaking....badly enough that it needs to be repaired. so what is the best seal to use? can I try to correct this leak while the motor remains in the car? I have to remove the transmission anyways so is it best I do it then? really frustrated with this motor. Any thoughts or direction is greatly appreciated.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 383 rear main seal leak? [Re: Tommy The Chryco] #2599788
01/01/19 01:26 PM
01/01/19 01:26 PM
IL
furious70 Offline
furious70  Offline
IL
Per some other's suggestions more than a decade ago I was able to roll a factory seal out and roll a new rope seal in with everything in the car. It was leaking bad enough that it would drip on the ground several times a minute. These days it doesn't leak any worse than the average big block. I probably got lucky.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 383 rear main seal leak? [Re: Tommy The Chryco] #2600261
01/02/19 01:21 AM
01/02/19 01:21 AM
I'm in the middle of trying one of 440 Source Viton rear main seal on a motor I'm having issues on sealing the rear main seal runaway I haven't had one leak in a lot of years and now I've had several motors leak puke I may have a issue with the new batch of 10 rear main seals I bought earlier this year being bad confused
I'll know more tomorrow on if this is a good fix or not after running on the engine run stand, I'll post my results wrench
Re: 383 rear main seal leak? [Re: Tommy The Chryco] #2600295
01/02/19 02:54 AM
01/02/19 02:54 AM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
This space not for rent.
Re: 383 rear main seal leak? [Re: Tommy The Chryco] #2600671
01/02/19 10:04 PM
01/02/19 10:04 PM
The 400 Source brown Viton rear seals fixed my leak up boogie
I had used two other new black seals with no luck on this motor whiney
I do use a sealer, Permatex adhesive sealant only, on the sides of the seal holder to seal the holder to the block on both sides towards the crankshaft flange and the bottom also by using a thin putty knife to try and force the sealer into the cracks between the block and seal holder bottom also wrench up
I change the seal holder also twice so I may have had multiple problems, not just the defective seals confused
IHTHs thumbs
Re: 383 rear main seal leak? [Re: Cab_Burge] #2600701
01/02/19 11:22 PM
01/02/19 11:22 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Is that the low-deck division of 440 Source? whistling
In addition to the "strips" or pipe cleaners, or just the sealant by itself? work
Re: 383 rear main seal leak? [Re: Tommy The Chryco] #2600771
01/03/19 01:50 AM
01/03/19 01:50 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
When it comes to rear main leaks, I've had better luck using the newer CNC aluminum rear main seal retainers, over the OEM retainer.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 383 rear main seal leak? [Re: DrCharles] #2601299
01/04/19 01:50 AM
01/04/19 01:50 AM
Oops, it pays to proof read blush
For those that don't know, the seam size rear main seal fits all the B,RB and Gen 2 426 Hemi motors scope up
I do use the side seals ALWAYS along with the sealant thumbs
