Innovate #3844 A/F ratio gauge set. Info needed #2599347
12/31/18 06:12 PM
12/31/18 06:12 PM
RapidRobert Offline OP
I was considering one & thought I had red some reviews here that were good (but it was quite awhile back) then I saw some reviews elsewhere that were pretty bad. Any thoughts/suggestions. thank you for your time
Re: Innovate #3844 A/F ratio gauge set. Info needed [Re: RapidRobert] #2599351
12/31/18 06:24 PM
12/31/18 06:24 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I have a pair of them in my hot rod. since the intake is divided into two plenums, I got one gauge for each side. No problems, other than they don't show up in video.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Innovate #3844 A/F ratio gauge set. Info needed [Re: Hemi_Joel] #2599372
12/31/18 07:29 PM
12/31/18 07:29 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I had real good luck with mine. beer
Re: Innovate #3844 A/F ratio gauge set. Info needed [Re: RapidRobert] #2599465
12/31/18 09:21 PM
12/31/18 09:21 PM
Az
HOT IN AZ Offline
HOT IN AZ  Offline
Az
Not the same but I have one of their MTX-L PLUS kits and to this day I have not been able to get a reading..hot to battery..new sensor..goes thru calibration perfect but that's it. Will call and see what they say but I have pretty much changed everything.
Re: Innovate #3844 A/F ratio gauge set. Info needed [Re: RapidRobert] #2599750
01/01/19 12:29 PM
01/01/19 12:29 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Also not the same but I have two of their LC-2 units feeding my EFI and they have been flawless.
68 Barracuda Formula S 340
Re: Innovate #3844 A/F ratio gauge set. Info needed [Re: RapidRobert] #2599934
01/01/19 03:39 PM
01/01/19 03:39 PM
central il.
second 70 Offline
second 70  Offline
central il.
Mine has been trouble free for years. Easy install
Re: Innovate #3844 A/F ratio gauge set. Info needed [Re: second 70] #2600237
01/01/19 11:41 PM
01/01/19 11:41 PM
I'm still on the fence but thanks guys for the input. Appreciated!
