Page 1 of 4 1 2 3 4
1970 340 vs. 1995 360 #259882
03/20/09 11:55 AM
03/20/09 11:55 AM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
Hey guys,
My little brother has a complete 1970 340 with J heads that I believe has one rebuild and should be .30 over with all stock parts except for the cam. He was originally going to build it for his 1971 Demon. A guy at his work just let him know that he has a 360 out of a 1995 Dodge truck that comes with the trans and all of the accessories and the harness for $500. It supposedly has 92,000 miles and they are mostly highway miles. My question to you guys is , is it worth it? I believe that my little brother wants to keep a somewhat stock look running a carb and everything but we were wondering about all of the internals of the newer motor. Would it bolt up to the original 727 he is going to use? Is it all roller lifters and cam? Is it a stronger block? Are the heads any good? Im guessing an intake and 4 Bbl carb could be put on it?
I am assuming if he goes this route he would just sell off all of the stuff he doesnt use, paint the engine the correct orange and make it look as close to stock as possible.
What do you guys think?
Thanks,
Brian
Re: 1970 340 vs. 1995 360 [Re: RAUPLEMINZE454] #259883
03/20/09 12:12 PM
03/20/09 12:12 PM
Indiana
P
Pentastar440 Offline
P
Indiana
The '95 5.9 (360) is a roller motor and will bolt up to a 727.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 1970 340 vs. 1995 360 [Re: Pentastar440] #259884
03/20/09 01:09 PM
03/20/09 01:09 PM
340 over a 360 no matter what the condition anytime...
Re: 1970 340 vs. 1995 360 [Re: RAUPLEMINZE454] #259885
03/20/09 01:13 PM
03/20/09 01:13 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
use the 360, then sell me the 340 really cheap
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: 1970 340 vs. 1995 360 #259886
03/20/09 01:15 PM
03/20/09 01:15 PM
P
Paul_Fancsali Offline
P
Having both my vote is the 340 period. The roller cam 360 is a truck motor Can they run sure but the 340 is a easier build with more power
Re: 1970 340 vs. 1995 360 [Re: Paul_Fancsali] #259887
03/20/09 01:32 PM
03/20/09 01:32 PM
BC Canada
cudasam Offline
cudasam  Offline
BC Canada
I vote for the 360. Cheaper to build, roller cam , so no oil additive issues, and if you blow it up, another one is just a wrecking yard away
Re: 1970 340 vs. 1995 360 [Re: cudasam] #259888
03/20/09 01:34 PM
03/20/09 01:34 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
yes i agree, then sell me the 340 really really cheap
Re: 1970 340 vs. 1995 360 [Re: RAUPLEMINZE454] #259889
03/20/09 01:53 PM
03/20/09 01:53 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I say keep the 340, buy the 360 and build a stroker out ov it
Common sense is a flower that does not grow in everybody's garden
Re: 1970 340 vs. 1995 360 #259890
03/20/09 01:59 PM
03/20/09 01:59 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
360 over a 340 no matter what....
20 more cubes
cheaper replacement pistons/rings
'95 in particular
magnum engine will have magnum heads (closed chamber
mag engine will be roller cam
how much do you want to "build" it? clean it up/rering, maybe a cam swap & tchain and go? or bore & new pistons?
how wild do you want it to be?
2017 Grand Cherokee Overland
Re: 1970 340 vs. 1995 360 [Re: RAUPLEMINZE454] #259891
03/20/09 02:01 PM
03/20/09 02:01 PM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
360 more low end torque, big ger crank,but may have less compression thana 340
Re: 1970 340 vs. 1995 360 [Re: Ron_M] #259892
03/20/09 02:30 PM
03/20/09 02:30 PM
that'd be what I'd do
Re: 1970 340 vs. 1995 360 [Re: RAUPLEMINZE454] #259893
03/20/09 04:37 PM
03/20/09 04:37 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
Stock the 360 makes more power than a stock 340. Equally built the 360 makes more power than a 340.
The magnum heads on the 360 are a better head stock than the 340 heads stock and will be more tolerant of todays gas.
The the 360 has a roller cam but stamped rockers.
You will need a car oil pan for the 360. You will need either an external balanced torque converter or flex plate.
Since niether motor is stock to the car use the 360 and sell the 340 to finance the parts you need for the 360. The 340 is worth more to the restoration crowd or those that see the 340 through rose colored glasses and think its better.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: 1970 340 vs. 1995 360 [Re: dgc333] #259894
03/20/09 04:51 PM
03/20/09 04:51 PM
McHenry, Illinois
McHenry, Illinois
Sorry guys,
I should have stated that my brother just wants a strong street cruiser in the 400 HP range. The car might see the track once a year. How does the price sound for the 360?
Thanks,
Brian
Re: 1970 340 vs. 1995 360 [Re: RAUPLEMINZE454] #259895
03/20/09 05:08 PM
03/20/09 05:08 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I would buy the 360 and use it. If he is going to a carb, he can pick the appropriate intake. Are there roller replacement cams available where you can re-use the lifters like a Chevy? That would be great. Over-all, I think the 360 is a better engine due to the stroke advantage.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: 1970 340 vs. 1995 360 [Re: dgc333] #259896
03/20/09 06:11 PM
03/20/09 06:11 PM
Really i don't recall the 360 ever being rated at 275 h.p. and anyone that knows and i have owned more then a few that rating is low its more like 300 or more..i'll put a stock 340 up against a stock 360 any day of the week,you might have more torque down low but by mid track i'll be blowing right by ya'!!!
Re: 1970 340 vs. 1995 360 #259897
03/20/09 06:34 PM
03/20/09 06:34 PM
McHenry, Illinois
McHenry, Illinois
What do you guys think would be a good price for the 360 without transmission or harness? He was asking $500 for everything.
Re: 1970 340 vs. 1995 360 [Re: dgc333] #259898
03/20/09 06:43 PM
03/20/09 06:43 PM
I have never seen a 360 magnum make more power than a 340 built up the same way. The 340 has a bigger bore diameter than a 360 and you can run any stroker crank in either engine. For example: 4 inch crank in 30 over 360= 408. Same crank in 30 over 340= 416. Hmmmmmmm? Now as far as roller lifters go, yes the mgnum motors have them stock, but you can put roller lifters in a 340, so if lifters are that important to your build, then maybe the 360 should be your choice. There are probaby pros and cons for either build, but 340s do make more power, straight up. Also magnum heads use 10 bolt valve covers that would look very wrong in that car. My 2 cents.....
Re: 1970 340 vs. 1995 360 [Re: ] #259899
03/20/09 08:32 PM
03/20/09 08:32 PM
BC Canada
cudasam Offline
cudasam  Offline
BC Canada
I have a 360 magnum in my car,and I used the 340 five-bolt valve covers and the water pump and housing and v-belts. Looks stock
Re: 1970 340 vs. 1995 360 [Re: ] #259900
03/20/09 08:37 PM
03/20/09 08:37 PM
BC Canada
cudasam Offline
cudasam  Offline
BC Canada
The 340 is an awesome motor. They don't call it the "giant-killer" for nothing. It's just rarer and more expensive than a 360. A bare 340 block is worth a way more than a good low-mile 360 complete. For a street car, I use the 360.
Re: 1970 340 vs. 1995 360 [Re: cudasam] #259901
03/20/09 08:53 PM
03/20/09 08:53 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Less filling
Travis..
Page 1 of 4 1 2 3 4
