Why doesn’t my Magnum 5.9 sound good?
#2598768
12/30/18 01:32 PM
12/30/18 01:32 PM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
This is a subjective thing but I think most of us know a good sounding V8 when we hear one. My engine is an old Magnum 300 crate engine. Demon 650 carb, Mopar M2 dual plane intake, Doug’s headers, Jones Max Flow flow-through mufflers, no cross-over pipe.
Obviously I’ve got a pretty mild cam and low compression...but something just doesn’t sound right. The exhaust seems kinda flat...no crispness or rumble, even at WOT. I didn’t want the echoey/hollow sound from Flowmaster type mufflers and I thought the flow through mufflers would have been the key to getting some sharper/better sound...but did I just pick the wrong style muffler?
Or...could this be a symptom of something else? Maybe it’s a timing/tune issue? The motor pulls ok but it’s not even close to the stock 5.0 Coyote in my Mustang...which has more hp but less (advertised) torque and in a much heavier car.
Any input is welcome.
Re: Why doesn’t my Magnum 5.9 sound good?
[Re: MRGTX]
#2598777
12/30/18 01:42 PM
12/30/18 01:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You have a broomstick for a cam. The 380hp version of that engine was essentially a cam and intake swap you might consider that. https://www.hotrod.com/articles/mopp-0303-360-crate-engine-buildup/
[Re: MRGTX]
#2598783
12/30/18 01:59 PM
12/30/18 01:59 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
that motor is not going to run ANYTHING like your coyote 5.0....as said you have a broom stick. up the compression and put a big cam in if you want some rumble that has power to back it up.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: MRGTX]
#2598788
12/30/18 02:09 PM
12/30/18 02:09 PM
Supercuda
About to go away
About to go away
up yours
No need to up the compression. As I said, the 380hp version is nothing more than a production line truck 5.9 with a cam and single plane intake swap. the 300hp version is a dual plane intake swap only.
Read the link for tuning details and dyno info on the 380hp version.
[Re: MRGTX]
#2598832
12/30/18 03:26 PM
12/30/18 03:26 PM
Posts: 20,204 Park Forest, IL
slantzilla
Park Forest, IL
I've had 2 5.9 trucks and my friends have also had a few. Every one of them sounded weird at idle like they had a burnt valve or something, especially with a non stock exhaust on them.
[Re: slantzilla]
#2598856
12/30/18 04:27 PM
12/30/18 04:27 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
My Durango has a Cherry Bomb- Flowmaster copy installed by the PO. Sounds pretty good at idle but the drone at cruise and crackle when I let off is getting to me. I'm going to try the short-glasspack-for-a-resonator trick to quiet it down some. To me, it sounds like most any other stock vehicle with Flowmasters. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: MRGTX]
#2598877
12/30/18 05:47 PM
12/30/18 05:47 PM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
I just looked at the internal view of the Jones Max Flow. It's a knock-off of a Magnaflow, which is a knock-off of a Dynomax Ultra Flow Welded. None of those mufflers do ANY tuning at all - none. They are just straight-through resonators basically - similar to a glasspack, but oval. Plus they all have a smooth round perf core - the only way they get loud is when you are at WOT. They sound "flat." If you run the right aggressive mufflers that do some tuning, you'll get sound.
[Re: Sunroofcuda]
#2599089
12/31/18 04:57 AM
12/31/18 04:57 AM
Posts: 969 manitoba canada
BleedDodge
manitoba canada
None of those mufflers do ANY tuning at all - none. They are just straight-through resonators basically - similar to a glasspack Ok so like a powerstick then I guess ? Or what.
[Re: BleedDodge]
#2599366
12/31/18 07:16 PM
12/31/18 07:16 PM
Sunroofcuda
Highland, MI.
None of those mufflers do ANY tuning at all - none. They are just straight-through resonators basically - similar to a glasspack Ok so like a powerstick then I guess ? Or what. Mine do tune the exhaust. There are others that "tune" also - like Dynomax Super Turbos, Flowmasters, Cherry Bomb Vortex, Borla, etc.
