So, where did YOU mount your MSD?
#2598403
12/29/18 03:26 PM
12/29/18 03:26 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Looking for ideas to keep it somewhat subtle
'72 Plymouth b-body, big block, Digital 6AL that doesn't really fit under the battery tray...
Old, tired, and sometimes broke down. Me, not my car...
Re: So, where did YOU mount your MSD?
[Re: Shoozy]
#2598426
12/29/18 04:10 PM
12/29/18 04:10 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
on the shelf... and running the Rev-N-Nator.
( LOL, j/k I had to, sorry )
[Re: dvw]
#2598614
12/29/18 11:43 PM
12/29/18 11:43 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
MSD fits fine under a 1970 B body tray. Is a 72 that much different? Doug Same place mine went.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2598689
12/30/18 03:47 AM
12/30/18 03:47 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
MSD fits fine under a 1970 B body tray. Is a 72 that much different? Doug Same place mine went. A lot of room between the core support and headlights as well. I have mine in front of the batt. tray '73 Dart Sport. I need to make a blackout plate in front of it as you can see it through the grill. It is a marine 7AL-2 if that makes any difference. Been running in a number of different Dodge products since 1999. Starting with this one. You can just see the box at the bottom of the pic.
[Re: wingman]
#2598717
12/30/18 10:48 AM
12/30/18 10:48 AM
Shoozy
Southern by Choice
MSD fits fine under a 1970 B body tray. Is a 72 that much different? Doug Same place mine went. Either of you have a pic? That was my first choice but I'm just not seeing it with the big plug on the digital 6A
[Re: BlueRacer69]
#2598842
12/30/18 03:58 PM
12/30/18 03:58 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I wouldn't mount a MSD if someone paid me. Nothing but junk. I've had 2 of them go south on me. Won't use them anymore. Have you contacted MSD (Now Holley)? We use thousands of their products ever year. Yes, there have been parts that have failed. We return them and they repair/replace at no charge and say there was nothing wrong with it. They don't want to have a bad name out there.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 451Mopar]
#2598850
12/30/18 04:18 PM
12/30/18 04:18 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
I must have gotten the good MSD6AL back around 1990. Still works fine. I did think it went out on me once. Cooling the car at the track and got some water trapped around the magnetic pickup connection that was wrapped in electrical tape. I was using the points trigger. Anyhow, unwrapped the tape and dryed the mag pickup connection, and no more problems. On The Charger, I had the box mounted on the inner fender in plain view so it would be easy to change the RPM limit pills. On the Convertible, I mounted the CD box (Crane HI-6) under the battery tray. I was thinking the same mi is from 89.
Ok
[Re: Shoozy]
#2600044
01/01/19 07:05 PM
01/01/19 07:05 PM
Shoozy
Southern by Choice
Made up a mount and got it in, under the battery tray, out of the wet, but with some airflow. Can't see the LED, but since it fired right up I guess I don't need to at this point. Thanks for the ideas guys
[Re: Shoozy]
#2600647
01/02/19 09:31 PM
01/02/19 09:31 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Mounted it on the back side of the firewall where the heater box used to be. The RPM limiter chips are nice and accessible. Sort of out of the weather other than the cowl leaks.....
