RAM TECHS? 08 RAM STALLS AT STOPLIGHT #2588981
12/08/18 11:04 AM
12/08/18 11:04 AM
crabman173 OP
crabman173 OP
Guys I have an 08 Hemi Ram--Great truck with 200K pampered miles
every now and then you are cruising along and when you come to a stop it will stall--fires right back up and no big deal does it once every 6 months but has done it twice in two days now--what is up? What do i need to replace, clean, fix?? Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589062
12/08/18 04:34 PM
12/08/18 04:34 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
How old is the battery? Is the alternator charging fully?
I've seen quite a few late models that 'fired right up' but had idle/stalling issues because the battery was actually weak. The systems in new(er) vehicles are much more dependent on having a specific voltage.
My twocents to give this a bump
John
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589068
12/08/18 04:51 PM
12/08/18 04:51 PM
crabman173 OP
crabman173 OP
Has one year old Interstate but i will check it--someone else mentioned throttle body issues as it is fly by wire--I just did not know what the heck it could be Thanks
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589249
12/09/18 02:37 AM
12/09/18 02:37 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
does drive by wire have a IAC valve?
my ladder of success is missing some rungs
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589255
12/09/18 03:31 AM
12/09/18 03:31 AM
Inland Northwest
GB5andGY8 Offline
GB5andGY8  Offline
Inland Northwest
My wife's similar vintage '07 Dodge Nitro with 160K would occasionally stall at idle or near idle speeds, during pulling into parking stalls, etc.
No PCM codes were thrown, and we chased all sort of avenues without much luck including reflashing the PCM itself. Turns out is was the EGR valve which was heavily sooted. You can try and clean it, but ultimately we replaced our valve and the problem didn't return.
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589326
12/09/18 01:37 PM
12/09/18 01:37 PM
crabman173 OP
crabman173 OP
Thanks everyone i will check the EGR
was told throttle body because it is drive by wire so any ideas on that?
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589426
12/09/18 04:18 PM
12/09/18 04:18 PM
SattyNoCar Offline
SattyNoCar  Offline
Has the throttle body ever been cleaned?
John
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589481
12/09/18 05:48 PM
12/09/18 05:48 PM
crabman173 OP
crabman173 OP
Nope never touched it so guessing take it off spray it out?
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2589486
12/09/18 05:59 PM
12/09/18 05:59 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Definitely clean the throttle body. You can probably get by with just pushing it open and using a rag with brake or carb cleaner to remove the carbon buildup unless it's really bad.
I also had issues with the crank position sensor on mine. I would occasionally have stalling problems, usually coasting down to a light. It lost crank signal once, then took forever to start a year or two back. Replaced it and it hasn't stalled since. Hard to verify that though without a scantool on it when it's acting up for you.
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2591457
12/13/18 07:51 PM
12/13/18 07:51 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
There's a similar thread in the "general" section right now. Different motor, so might not help...
https://board.moparts.org/ubbthreads/ubbt...tml#Post2591280
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: Fat_Mike] #2596959
12/25/18 11:14 PM
12/25/18 11:14 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
did you recently put new plugs in it? if you did but did not have this problem before, and you put anything but dealer spark plugs in it, that may be the problem. i was going to put autolites in my 5.7 but my friend whom is a district mgr and used to teach at st louis mo training center,stopped me. he said there is a tsb concerning the use of non dealer plugs that will cause what you are describing. i was skeptical but ohmed them with the autolites and store bought champions. they were different. he also said even with scan tool hooked up, there is no way to tell why it died or stalled. hope this helps.
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: ] #2598069
12/28/18 06:05 PM
12/28/18 06:05 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
My 2003 will do that same exact thing every few months. Thanks for posting as i will try some of the ideas listed here.
Stu
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT [Re: MidPenMopar] #2609661
01/21/19 12:04 AM
01/21/19 12:04 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Have had trucks where the lock up trans convertor doesn't release when coming to a stop, causing the truck to stall just like a stick truck that you would forget to push the clutch in. Have you had the trans serviced recently? Some times the filter is not installed correctly causing the pressure to drop. Remember pressure holds the lockup off not on.
