Re: Aluminum Main caps from one block to another???
[Re: moparlulu]
#2597845
12/28/18 01:25 AM
12/28/18 01:25 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
The only reason that I can see why they wouldn't fit if when the damage occurred it may have damaged the caps. Other had that probably a slight clean up with a align bore. The caps are made to fit any block of the same main journal size.
[Re: moparlulu]
#2597930
12/28/18 11:11 AM
12/28/18 11:11 AM
Posts: 4,457 Washington
madscientist
Washington
The old block developed a crack in #8 cyl bore. that's the main reason I'm changing blocks. I knew I'd have to have the other block aligned bored was just wondering about the fitting of the cap from one to the other, as I was under the impression it was a block specific kind of thing. As long as they fit tight in the registers you'll be GTG. You may have to cut a bit off the caps to get something to work with. I've done it may times.
[Re: moparlulu]
#2598001
12/28/18 03:15 PM
12/28/18 03:15 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
Did it crack the cylinder wall only or is it cracked down in the main webbing ?
[Re: Jerry]
#2598920
12/30/18 07:31 PM
12/30/18 07:31 PM
Posts: 771 Btween a rock and a hard place
moparlulu
7075 aluminum has a higher tendency to crack since they are harder. at bcr we have had a few caps crack from guys really pushing the envelope over the years, but the percentage of caps that cracked vs the percentage that we produced is down around .1% Nice! This motor is and was a fairly mild engine compared to most street/strip motors on here. Really, did I even need them??? I'm not concerned in the least about breaking a cap, I just liked the idea of "Lessing the load on a block"...... Hindsight........ should of went to a different shop that checked thickness in the first place. lesson learner!!! Thank again everyone
