An image of the 572 with the Doug headers that will be ran in the car.
When we ran the tests yesterday the neighbors were out playing with there horses next door, I sent a helper over to ask them if it would be ok if we ran the engine, their reply was sure the horses will just have to get accustom to the noise.
The exhaust system is working Yea!
I'm still only getting 5 lbs of vacuum from the gauge on the valve cover @ 3500 rpm and drops with more speed, so I removed the hose from the pump and installed the gauge direct to find I have plenty of vacuum at the pump 15+.
I guess the next test will be a leak down test on the cylinders, other than that I'm not sure what else to do?
We also took the time to
set the GTX on the scales to find the car without drive is 3308 lbs {the drive was out of town}
The reading were a few lbs light on the right rear and a few lbs heavy on the left front.
After looking at the picture of the GTX I see I need to black out the front wheel wells
