Holley Carb Bolt on to Stock Intake. #2596745
12/25/18 02:40 PM
12/25/18 02:40 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I've tried a 4160 series carb that would not bolt straight up to my 69 Roadrunner 383HP stock intake. Is it possible to get a 600 or 750 Holley square bore that will bolt right up without an adapter plate of some kind?
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2596762
12/25/18 03:11 PM
12/25/18 03:11 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
4150 and 4160 should have same bolt pattern. Does it not bolt up or do the blades not open? Merry Christmas.
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2596779
12/25/18 03:35 PM
12/25/18 03:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
No. Square bore Holleys are all the same. AFB and AVS, not so much.
http://www.thecarburetorshop.com/Four_barrel_mounting_flanges.htm
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2596836
12/25/18 05:49 PM
12/25/18 05:49 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
This sounds kind of familiar. Is it the bolt pattern, or the Holley linkage getting in the way of being able to tighten the carb properly? It might not need an adapter, but a small spacer to raise the linkage so it doesn't hit the intake.
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2596871
12/25/18 06:53 PM
12/25/18 06:53 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
iagree It's not usually the bolt pattern or throttle bores that prevent the carb from bolting on to a stock manifold, it's the linkage that overhangs the base and won't clear the manifold flange without a spacer.
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2596943
12/25/18 10:26 PM
12/25/18 10:26 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Bolt pattern and throttle bores were good on the 4160 I had. Issue is the linkages on the left and right side. The carb I started the fit with also had an electric choke. The choke idle screw hit the intake on the rh side. The LH side throttle linkage that hangs down hit on the left side of the intake.
I suppose I need a spacer to raise that carb up a bit?
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2597627
12/27/18 03:34 PM
12/27/18 03:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Have you measured how much additional clearance is needed?
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2598617
12/29/18 11:52 PM
12/29/18 11:52 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
.500 spacer would do it. Holley sells one for the stock intake but the bores are 1 9/16. I need 1 11/16 for the 750cfm I want to use.
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2598686
12/30/18 03:35 AM
12/30/18 03:35 AM
BradH Offline
BradH  Offline
Plenty of options for 1/2" spacers available...
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2598769
12/30/18 01:34 PM
12/30/18 01:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Don't sweat it too much for 4 hole spacer. As long as the 4 holes are as large or larger than the carb barrels, it's just fine. Just make sure they are not smaller...
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2599196
12/31/18 01:58 PM
12/31/18 01:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Summit G-1402
Re: Holley Carb Bolt on to Stock Intake. [Re: TimS] #2599492
12/31/18 10:14 PM
12/31/18 10:14 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
If you are using the stock intake why would you put a holley on it? Put a carter on it and everything works.
Real Men shift for themselves
Re: Holley Carb Bolt on to Stock Intake. [Re: 1DGEMAN] #2600535
01/02/19 05:36 PM
01/02/19 05:36 PM
BradH Offline
BradH  Offline
I ran the AVS my '69 383 Super Bee came with for a while. It was "OK, but wasn't exactly impressive, either.
Some BB Mopars came with factory Holley 4160s in 1970 & 1971, so it's not like the factory wasn't open to alternatives to Carter.
