Custom push rods #2595690
12/23/18 02:51 AM
12/23/18 02:51 AM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I remember reading here that there was a company that would send you a checking push rod to measure then order from them. I might need to get some new push rods and still haven't made up my mind yet. I made my last set from a kit and they turned out pretty good but some store bought ones would save me a bunch of work.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Custom push rods [Re: fourgearsavoy] #2595692
12/23/18 03:09 AM
12/23/18 03:09 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
We made our own checking push rod from an old one. Do that and measure your own.
Re: Custom push rods [Re: max_maniac] #2595694
12/23/18 03:16 AM
12/23/18 03:16 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Jegs sells some nice size checking pushrods. I stocked up earlier in the year
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Custom push rods [Re: fourgearsavoy] #2595704
12/23/18 04:24 AM
12/23/18 04:24 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
PM me your address and I'll send ya one.
Re: Custom push rods [Re: fourgearsavoy] #2595705
12/23/18 05:07 AM
12/23/18 05:07 AM
Cab_Burge Online work
Cab_Burge  Online Work
Do you need one for a B or RB motor with solid lifter or hydraulics and do you need ball and cup or ball and ball? Last thing w=hat size are the ends you need on each end, 1/4, 5/16 or 3/8?
Re: Custom push rods [Re: fourgearsavoy] #2595713
12/23/18 09:00 AM
12/23/18 09:00 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I got one from Hughes engine
Re: Custom push rods [Re: fourgearsavoy] #2595718
12/23/18 09:47 AM
12/23/18 09:47 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You can cut an old one in two and thread the cut ends, put a short piece of threaded rod between and a couple jam nuts.
Re: Custom push rods [Re: dthemi] #2595765
12/23/18 01:26 PM
12/23/18 01:26 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Thats what I did, and sent both of them to Smith Brothers. They returned them with the new pushrods. I didnt want
to take a chance on my measurements. Nice guys to work with.
Re: Custom push rods [Re: fourgearsavoy] #2596017
12/23/18 11:06 PM
12/23/18 11:06 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Smith Brothers Pushrods is the only place I will get mine. I just ordered a very custom set for a 428 Cobra Jet. Talk to Eric, good guy.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Custom push rods [Re: Troy] #2596129
12/24/18 02:38 AM
12/24/18 02:38 AM
Smith Bros. screwed me once around 8 years ago when they where here in Bend, I have not used them since then and won't again down
I use Mantons now and will for a long time to come, way better quality and prices also up work
Re: Custom push rods [Re: fourgearsavoy] #2596156
12/24/18 04:11 AM
12/24/18 04:11 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Trend is who I recommend
Re: Custom push rods [Re: fourgearsavoy] #2596203
12/24/18 11:40 AM
12/24/18 11:40 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Trend here also.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Custom push rods [Re: fourgearsavoy] #2596225
12/24/18 12:24 PM
12/24/18 12:24 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have had very good luck with Smith Brothers and found them easy to work with.
Re: Custom push rods [Re: Cab_Burge] #2596845
12/25/18 06:03 PM
12/25/18 06:03 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Can you please explain "screwed me"? They always got my orders right so this sounds really odd.
Re: Custom push rods [Re: PorkyPig] #2596861
12/25/18 06:34 PM
12/25/18 06:34 PM
I paid for 3/8x.120 wall ball and cup and when one of them broke in half on the dyno testing, it broke due to a defect in the material I was told by Piere that they where .083 wall, not the .120 wall I ordered and paid him for runaway puke
When the bad one broke at around 5200 RPM on the engine dyno it took out the one beside it and the upper half ended up gouging the cam lobe and lifter bushing after the Crower solid roller lifter was spit out, which cause the link bar to break the top of that set of lifters off whiney
They replace the two bad pushrods but did not offer to help fix the cam and replace the pair of broken lifters down
I ordered a set of Manton .120 wall and put the motor back on the dyno with the Smith Bros. and made three pulls and then switch the pushrods to the Manton set with no other changes, those pushrods made 8 HP more and raised the peak HP RPM by 300 RPM boogie work
This forum is for all of us to try and help each other, I hope this does that up
Re: Custom push rods [Re: Cab_Burge] #2598196
12/28/18 11:45 PM
12/28/18 11:45 PM
the hardware store has these thin (5/16?) shafts that are threaded on each end (LH on one end), not sure what they are for, didn't pay attention & from a bent junk pushrod, I cut & JB welded a ball on one end & a threaded shaft with 2 nuts to lock it solid at a particular height into the other. had more range than the tailor made ones (& cheaper) plus the satisfaction of doing it your self.
