71-74 B Rear qtr window leading edge seal differences? #2595778
12/23/18 02:13 PM
12/23/18 02:13 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Metro sells their part# VS7-F for all 71-74 B bodies. have had a few people now tell me the metal tab is about 1/2" too short.
See the picture.
Top is an original
Middle a 71-74 E body VS7-M with a longer tab like I'm told the 71-74 B body should have.
Bottom the "too short" VS7-F
Question is, are all these the same on 71-4 B bodies? Should they all have the longer tab. Theres a screw hole and I'm told with the short tab a new screw hole has to be drilled and the original hole in the body is exposed.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 71-74 B Rear qtr window leading edge seal differences? [Re: 71TA] #2595898
12/23/18 06:55 PM
12/23/18 06:55 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
I may have an original from a 71 if I can find it I will make the comparison and get back to you.
Re: 71-74 B Rear qtr window leading edge seal differences? [Re: 71TA] #2595947
12/23/18 08:51 PM
12/23/18 08:51 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks!
I did some digging in the parts books.
Top picture
71 B bodies used a rear qtr window leading edge seal with a long tab. Part# 3581170-1
Bottom picture
72-74 B bodies used a rear qtr window leading edge seal with a short tab. Part# 3582136-7
Metro sells the part with the short tab for all 71-74 B bodies. I'll have to bring this new info I found to their attention and see if we can get correct ones made for 71 B bodies The E body seal looks VERY similar to and has the longer tab like the 71 B body. I'll have to see if that one fits / works on a 72-74 B body.
3581170-1 B 71 QTR WINDOW LEADING EDGE SEAL.jpg3582136  B 72-74 QTR WINDOW LEADING EDGE SEAL.jpg
Re: 71-74 B Rear qtr window leading edge seal differences? [Re: 71TA] #2596752
12/25/18 02:48 PM
12/25/18 02:48 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Yes mine is a 71 and has the longer tab. I believe I bought replacements fro Tom at RT Specialties, not sure where he is getting them
Re: 71-74 B Rear qtr window leading edge seal differences? [Re: 71TA] #2597067
12/26/18 09:35 AM
12/26/18 09:35 AM
MA
steve70 Offline
steve70  Offline
MA
I bought replacements years ago for my 71 Charger and the tab was too short.
1970 Challenger T/A 4 speed
Re: 71-74 B Rear qtr window leading edge seal differences? [Re: steve70] #2597634
12/27/18 03:47 PM
12/27/18 03:47 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Here's my experience (72SE):
Removed the old seal, the new seal slides in and this little metal tab goes through the whole in the rubber seal. Used some silicone spray as the seal was a very tight fit; which of course you want.
As we know with most repro parts they are usually a little off, the hole that was drilled in the seal was out of place so I had to drill a new whole and it had to be a little more oval for the rubber seal to fit over it.
Finished product, I am very happy with it and glad it was available in the aftermarket, mine have always looked like crap.
