restoring steelies #259543
03/19/09 09:19 PM
03/19/09 09:19 PM
Jefferson State
srt Offline OP
ESYC
srt  Offline OP
ESYC
Jefferson State
What's the best way to repair the crowning over on the lug openings of steel wheels. I have a set of 4 that appear that the lugs were hammered on with the impact and the lips are sort of rounded over. Is there a safe way to repair the openings?
Re: restoring steelies [Re: srt] #259544
03/21/09 10:43 AM
03/21/09 10:43 AM
Jefferson State
srt Offline OP
ESYC
srt  Offline OP
ESYC
Jefferson State
anyone?
Re: restoring steelies [Re: srt] #259545
03/22/09 09:01 AM
03/22/09 09:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats a good question ...
Re: restoring steelies [Re: JohnRR] #259546
03/23/09 01:41 PM
03/23/09 01:41 PM
Midwestern Indiana
duster2 Offline
Happy Birthday duster2  Offline
Midwestern Indiana
Take a flap grinding wheel and knock the high spots down , they will look much better.
It works.....
Re: restoring steelies [Re: duster2] #259547
03/24/09 08:31 PM
03/24/09 08:31 PM
It works.....
Look better, probably. But my concern would be why did that metal mushroom out and how much metal thickness would be left and would I feel safe with that wheel on the car?
Re: restoring steelies [Re: ] #259548
03/24/09 10:21 PM
03/24/09 10:21 PM
Jefferson State
srt Offline OP
ESYC
srt  Offline OP
ESYC
Jefferson State
The mushroomed out wheels lug holes appear to be from over tightening. It appears to be cosmetic as it's not severe. I know I can grind down the lug nuts to make sure it does not bottom against the hub/disc.
Is there a way to restore the lug openings?
Are ther two styles of lugs available?
Re: restoring steelies [Re: srt] #259549
03/25/09 10:10 AM
03/25/09 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The only way I can see to fix the lug holes is to weld a bead around the hole and redo the countersink to the stock specs .
I have a few hi dollar wheels that are the same way , I never put wheels on with an IMPACT gun , thats why they are SCREWED up .
Re: restoring steelies [Re: JohnRR] #259550
03/26/09 11:04 AM
03/26/09 11:04 AM
Jefferson State
srt Offline OP
ESYC
srt  Offline OP
ESYC
Jefferson State
Any idea if a wheel repair service can do that type of repair.
I thought about what you described, but I couldn't figure out how to get the centers precisely at the correct lug diameter and 72* arc. (360/5=72).
Re: restoring steelies [Re: srt] #259551
03/26/09 02:02 PM
03/26/09 02:02 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
You'd probably have to use a lathe. That's how we used to drill the 4" A body axles to 4.5" before the days of economical aftermarket axle. We centered them on a lathe, drilled and tapped new holes every 72* then used 1/2" screw in studs. Maybe steelies could be repaired the same way, build up the holes with weld, them center them on a lathe and remachine the holes every 72* with the proper angle. Only problem may be the area around the weld may have become hard and lead to cracking, maybe filler rod choice or some softing procedure will solve that.
