E Body door handles on an a body?
#2595264
12/21/18 10:52 PM
12/21/18 10:52 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
has anyone ever tried to put cuda or challenger door handles on a duster or dart before? and whats involved?
Hell Hath No Fury Like Mine
Re: E Body door handles on an a body?
[Re: sixpacksteve]
#2595379
12/22/18 04:16 AM
12/22/18 04:16 AM
Posts: 10,136 A Red State
SNK-EYZ
A Red State
The curve in the door handles of an E-Body might be an issue to following the sheet metal curve (or lack of).
There's also a difference between Challenger and Cuda door handles.
[Re: AARCONV]
#2595481
12/22/18 02:20 PM
12/22/18 02:20 PM
Posts: 19,408 north of coder
moparx
Find a left and right used door and cut out the sheetmetal around the handle assy and weld it in...that will be a start for ya... if you can get a junk door with complete latch assembly, it will be easy to duplicate the geometry needed for the A body door. if the latch is not there, at least you can get an idea of how much difference there is in the latch location, compared to the location on the A body door. then go from there. if the location[s] is off just a very small amount, maybe less than, or around, 1/2", possibly just raise or lower the handle pocket the amount needed to use the complete E body linkage with slight "tweeks" may work.
[Re: sixpacksteve]
#2595506
12/22/18 03:14 PM
12/22/18 03:14 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
anything can be done... maybe custom linkage system and served.
The "bigger" problem could be the cylinder system linkage ? being A and B bodies separated from the handle and E bodies as ( somehow ) part of the assembly without disturb one with the other ?
Maybe using the cylinder link from the E body and the handle link from the A body... both with tweaks on the opposite end.
[Re: sixpacksteve]
#2595873
12/23/18 06:03 PM
12/23/18 06:03 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Did anyone ever come up with a repop handle that doesn't break like the originals?
[Re: sixpacksteve]
#2596161
12/24/18 05:20 AM
12/24/18 05:20 AM
Posts: 10,568 Freeport IL USA
poorboy
Freeport IL USA
I've done a lot of door handle modifications over the years. I put a set of Dakota handles in my 48 Plymouth coupe that I think I still have pictures of, but I'm pretty sure it won't help much with the Cuda handles in an A body, other then maybe a process. Every time I've done a door handle swap, brings its own set of modifications, some transfer, some don't.
Pretty much, you cut the sheet metal around the new handle, and align it with the sheet metal of the old handle. Then you cut the old handle sheet metal out, and weld in the new sheet metal. After the outer handle is done, you may need to cut the section of the door latch out and do the same with it. After all the cutting and welding is done, you get to modify the inside linkage, the outside linkage, and the outer door lock linkage so they all function. Then you get to do body work over your welds and patches. Quite a lot of work to install poorer quality Cuda door handles in an A body. Gene
[Re: sixpacksteve]
#2596182
12/24/18 09:50 AM
12/24/18 09:50 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
some how i thought it would be a little easier. sounds like not even worth it!
[Re: NachoRT74]
#2607348
01/16/19 05:05 AM
01/16/19 05:05 AM
Posts: 1,965 ID/MT
Cheeto
ID/MT
Agreed. I have Dodge Spirit door handles in my '78 Pickup. Because the truck has a separate lock cylinder (like your A body) I used handles from the rear doors of the Spirit. The front handles on the Spirit have the key cylinder built into them...like an E body. This also meant I only had to mod one piece of linkage for the door latch.
Cheeto It's not perfect. It's not correct. It's not yours!
