Re: stainless or ceramic headers ??
[Re: Stanton]
#2595051
12/21/18 01:37 PM
12/21/18 01:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
stainless don't flake off.
Ceramic has been known to.
[Re: Supercuda]
#2595059
12/21/18 02:02 PM
12/21/18 02:02 PM
Posts: 19,366 north of coder
moparx
i bought a stainless set for my 392 at a swap. the guy modified the collector area for some reason [he said they hit the oil pan ?], but i will be doing further mods because of what i want to do. plus, i got them for a great price. stainless will, however, discolor, so keep this in mind. six of one, 1/2 a dozen of the other. then, there is the "it depends" on the coating. i have seen some coatings that are crap, while others last many, many years without issues in color or bonding.
[Re: Butterscotch71]
#2595099
12/21/18 03:48 PM
12/21/18 03:48 PM
Supercuda
About to go away
About to go away
up yours
Some types of stainless do rust... If your stainless is rusting, it ain't stainless, it's chinesium.
[Re: Dave Hall]
#2595282
12/21/18 11:21 PM
12/21/18 11:21 PM
Posts: 22,696 Bitopia
jcc
Bitopia
1. Its called "Stain LESS", not rust free. 2. Stainless is not appreciably different in density then steel, ie same weight 3. SS transmits heat less then steel 4. The suggestion of both would be my choice 5. 409 SS, unless coated would not be my choice 6. Regardless, never "wrap" for the street if you want to keep them. edit: "Common Name Density (g/cm3) Plain carbon steel AISI-SAE 1020 7.86 Stainless steel type 304 7.9" https://hypertextbook.com/facts/2004/KarenSutherland.shtmlThere are many alloys of each of course, with widely different mechanical properties for each class of material. SS generally has more useful preferred properties as corrosion and higher temps enter the process.
[Re: Supercuda]
#2595866
12/23/18 05:44 PM
12/23/18 05:44 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
Some types of stainless do rust... If your stainless is rusting, it ain't stainless, it's chinesium. Wrong
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
#2595878
12/23/18 06:13 PM
12/23/18 06:13 PM
Supercuda
About to go away
About to go away
up yours
Some types of stainless do rust... If your stainless is rusting, it ain't stainless, it's chinesium. Wrong You buy cheap crap, it's chinesium.
[Re: Stanton]
#2595974
12/23/18 09:39 PM
12/23/18 09:39 PM
Posts: 2,637 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I prefer ceramic because it's cooler under the hood. (Less burns on my hands and arms.) Stainless seems to be the rage now.
2011 Drag Pak Challenger
