Steering column gap question #2593764
12/18/18 02:46 PM
12/18/18 02:46 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Non Mopar but they have this problem too.What would cause this much gap between the collar and wheel.TIA.
Re: Steering column gap question [Re: 5carguy] #2593952
12/18/18 08:38 PM
12/18/18 08:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If they are assembled correctly, there is no gap
Re: Steering column gap question [Re: 5carguy] #2594043
12/19/18 12:38 AM
12/19/18 12:38 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
What year car? Pull the cap and switch and there are two sometimes three screws that come loose and if you tighten them up the gap gets smaller.
Re: Steering column gap question [Re: 5carguy] #2594809
12/20/18 09:13 PM
12/20/18 09:13 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Try loosing the column to dash mounting bolts & sliding the tube up.
Re: Steering column gap question [Re: 5carguy] #2595044
12/21/18 01:28 PM
12/21/18 01:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only thing holding the shaft in position is the snap ring on the top bearing. There is enough slop everywhere else for that shaft to move up in the column if that snap ring has somehow broken or come out.
