413 CROSS RAM MOTOR #2594822
12/20/18 09:56 PM
12/20/18 09:56 PM
NJ
O
owen Offline OP
owen  Offline OP
O
NJ
1960/1961 413 CAMSHAFT SPEC'S FOR A LONG RAM INTAKE OR # SAME AS ?
Re: 413 CROSS RAM MOTOR [Re: owen] #2594875
12/21/18 12:22 AM
12/21/18 12:22 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Not sure of exactly what your question is? For the record the 60-61 413 engines are usually called "Long Ram" engines and they had special cams as compared to single 4 barrel cars which were designed specifically for the ram induction engines.
Re: 413 CROSS RAM MOTOR [Re: ScottSmith_Harms] #2596538
12/24/18 10:04 PM
12/24/18 10:04 PM
NJ
O
owen Offline OP
owen  Offline OP
O
NJ
That's correct special cam. Does anyone know specs on this cam or part number or casting number?? As I want to install my long ram intakes on the 1961 413 motor I have.
Re: 413 CROSS RAM MOTOR [Re: owen] #2596547
12/24/18 10:37 PM
12/24/18 10:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: 413 CROSS RAM MOTOR [Re: Supercuda] #2596583
12/25/18 12:35 AM
12/25/18 12:35 AM
NJ
O
owen Offline OP
owen  Offline OP
O
NJ
UNBELIEVABLE !!! THANK YOU VERY MUCH !!!
