Stock 7 blade cooling fans info.... #2594375
12/19/18 07:01 PM
12/19/18 07:01 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I'm needing some if formation on these three fans...as in what car and what not if I can please.
Can anybody point in the right direction?
The first one is 46237 direct 7 blade 17.75
second one is 2780921 direct 7 blade 17.5
& third one is 2463657(?) 7 blade clutch fan that's small like 16.25
Moparlee
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2594377
12/19/18 07:08 PM
12/19/18 07:08 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Third pix
Moparlee
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2594381
12/19/18 07:21 PM
12/19/18 07:21 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
per GG's "white book": I don't see a 2463657?
2463376 = 6-blade 1966 a-body w/273
2780921 = 7-blade 1966 Imperial 440 & b/c-bodies w/273 & 318
Re: Stock 7 blade cooling fans info.... [Re: 6bblgt] #2594384
12/19/18 07:29 PM
12/19/18 07:29 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks a bunch....but the one part number you listed for 6 blade isn't the part number and it's a 7 blade.
Moparlee
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2594393
12/19/18 07:41 PM
12/19/18 07:41 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
it was the only 2463xxx fan listed, maybe it's from a truck ???
Re: Stock 7 blade cooling fans info.... [Re: 6bblgt] #2594397
12/19/18 07:48 PM
12/19/18 07:48 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I see how you got the the number......I was wondering since it wasn't painted on if it was from the 70's....I don't know....lol....just trying to learn and sell this if people may need the. I just didn't want to misinform and give the best/accurate info that I could fine.
Moparlee
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2594736
12/20/18 04:55 PM
12/20/18 04:55 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
The first one 46237 is not a part number, it’s a vendor code.
The following is from the Factory Parts Books:
Second one 2780921 is 1966 B & C body w/273 and 318 cu. in. Eng., w/o A/ Cond., w/ Cleaner Air Package, w/o Trailer Tow Pkg., 7 Blade
Third one 2463657 is 1964 & 1965 A body w/273 and 318 cu. in. Engine
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2594742
12/20/18 05:18 PM
12/20/18 05:18 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Moparlee
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2594846
12/20/18 11:00 PM
12/20/18 11:00 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I meant to look at the shop a few minutes ago but got sidetracked. The 7 blade direct drive one you have with that vendor number sounds like the same one I have the shop. I think that it has that same vendor number and it is oem on a 70 RR 383 4 speed car. The last three numbers stamped on it are 224 if I remember correctly. It is an 18” direct drive with a 1” spacer.
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2595080
12/21/18 02:40 PM
12/21/18 02:40 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have four of those all with the same vendor number as yours. Two of them have visible ink stamps with part no. 2863224 which is 70 383-440. I assume that is std cooling as the car I’m working on has a 22” radiator.
Re: Stock 7 blade cooling fans info.... [Re: Robbins] #2595138
12/21/18 05:38 PM
12/21/18 05:38 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Awesome thank you
Moparlee
